CHAWAWA
About CHAWAWA
  • Birthday 05/09/1976
    Toledo Ohio
Contact Methods
    Red Black 1999, FMF fattys.
CHAWAWA's Achievements
  1. I just got a set of holeshots gncc front and rear. we just went up north to mio mi. and i love my gncc. great hook up and you go in the direction you point the fronts so lean and hold on.
  2. wow so instead of buying a big boar kit we should just boar the crap out of it :shoothead: hay while im at it I think i will just cut the rods and and weld some rebar in them to make it a stroker as well. and you know i have a larg drill bit i sould make my own 34mm carbs wow i think you have something here. :: well that was fun. now that I look at it that is some funny shit. :yelrotflmao: :yelrotflmao: :yelrotflmao:
  3. so about 360 perhaps
  4. I just got my shee back together and it was punched out to 60 over and i was wondering what size that would make it. 370 or what :shrug: and I went from 30 over would i have to rejet.
  5. hay dishman could you do next day air to Toledo oh. 43615 if so how much extra. I need a crank for next week end. and are the barrings in good shape. can you send me ppics [email protected] thank you.
  6. A BLOW DRIER WILL MELT THE FOAM. IF IT DOESN'T HAVE A METAL FRAME THEN YOU CAN GENTLEY FOLD IN A TOWL SEVERAL TIMES SO THE TOWL WRAP IS NEATLY FOLDED. PLACE ON FLOOR AND STAND ON TOWL. DO NOT TWIST YOU ARE JUST PRESSING THE WATER FROM THE FILTER INTO THE TOWL.
  7. WELL SPLIT THE CASE AND IT SEEMS LIKE THE BARRINGS ARE BAD ON THE CRANK. THE ONE ON THE OUTSIDE ON THE CLUTCH SIDE IS LOOSE MY CONCERN IS THE BARRINGS IN THE CENTER THEY HAVE PLAY FROM SIDE TO SIDE. SO IM GUESSING I NEED A NEW CRANK. WELL LAST MOMENT BUT I NEED ONE ASAP I AM GIVEING MY 2 KIDS QUADS FOR X MAS AND I WOULD LIKE TO RIDE WITH THEM NEXT WEEKEND MY BUDGET IS UNDER $150 AND I LIVE IN TOLEDO OHIO. I AM WILLING TO DRIVE 2 HOURS AWAY. PLEASE HELP
  8. do you have a good crank and how much
  9. is this the same crank you have pics for on the other thread and is it $100.
  10. what year is the crank. is it $120 shiped
  11. I have a 99 shee with FMF fatty golds board at about 50 over not shure on compression yet son put back together yet and snorkel off, billet h2o, uni air filter, and boison reeds. I would like to get V force reeds and cool heads (not shure what domes to use). Do I need to advance my timeing or run better than 93 octane or is stock timeing and 93 ok.
  12. thank you that was perfect. I was telling a guy at work today that the oil in a 2 stroke was for the crank as well and he wanted proof.
  13. I am trying to find the pic a guy made of how a 2 stroke motor works. It was a rotateing motor picture.
  14. fly wheel puller is on the way should have it dissesembled soon
  15. yes a fly wheel puller is what I ment thanks I will see where I am at. I don't want to port the jugs cause I don't want to deal with the jetting that much. The temp changes so much around here and I ride in difrent locations and altitudes all the time and just to much to deal with. Was looking for other mods thanks for the good advice.
