Can only be a cylinder problem not rods or pistons. Do you think the base gasket thickness should increase
to compensate for the problem or should I have the domes cut.
I checked the stroke when Alcoholbanshee asked and it measured 54mm. No spacer plate on the stock setup.
Did not take notice of the old base gasket before sending it in.
These cylinders might have been decked before I dont know. Why did I not have this problem with
the stock crank and pistons. I thought that the 795 pistons made up for the 5mm longer rod.
Replaced stock crank with a hotrod stroker, wiseco,s and head spacer gasket. Shee not happy, not revving up. Plugs verry wet. Before 300 mains down to 240. Problem solved. Why smaller jets with this mod.
