vainavic
About vainavic
  • Birthday 11/23/1986
Contact Methods
  • AIM
    bgknicker
  • Website URL
    http://
    Kent city MIchigan
    97 banshee 420cc cheetah, ptr mids,
vainavic's Achievements
  1. I live in michigan so I think Im at sea level
  2. I was wondering what would it run like if one of the powervalves were stuck because that is the only thing i can think that would cause the problem
  3. I have a 420 cheetah, dg pipes, 34mm keihin carbs k&n filters timing at +4, I live in grand rapids michigan, I have a 40 pilot jet in, air screw out 2 turns 165 main needle in the middle and the plugs still say its rich, I have \played with the floats(just made sure they sit level) the thing sounds like it wants to start but just rolls over like two or three times. I must have tried everything but want it wants to run. I have lots of spark, 145psi with 21cc domes, any help would be great. Jeff
  4. I have a 420 cheetah, dg pipes, 34mm keihin carbs k&n filters timing at +4, I live in grand rapids michigan, I have a 40 pilot jet in, air screw out 2 turns 165 main needle in the middle and the plugs still say its rich, I have \played with the floats(just made sure they sit level) the thing sounds like it wants to start but just rolls over like two or three times. I must have tried everything but want it want to run. I have lots of spark, 145psi with 21cc domes, any help would be great. Jeff
  5. I miss typed I have 22cc domes I think I 1000ft above sea level in michigan, right?
  6. compression is 145psi, domes are 19cc, using 96 octane fuel
  7. I have a 421cc cheetah, lighten flywheel, 34mm pj carbs, taller gears in the tranny(rz 350), clutch, pipes etc, I have my timing at zero, I have an adjustable timing plate should I advance it, What would it help, and what would it change. Jetting? thanks jeff
  8. I have the stage four powervalves, if that helps, please any information would be great. I tried to call trinity yesterday but either the phone just rang or it was busy
  9. Hey your right I have no idea what Im doing, I am only 20 years old and have lots to learn, but I didnt say I didnt believe you, I just wanted to hear other peoples thoughts,
  10. I have a cheetah 420cc and someone told me that the valves will not open if I dont connect the hoses (from the powervalves) to a intake ports that I have to drill myself, I was wondering if anyone had some info on this. Firehead put up some pics but I would like to hear from some other people before i drill into 2k worth of cylinders, Does making the connect help or whats the story, I think if it was needed the jugs would have came with the ports already.
  11. Thanks for the help your a life saver. Why dont the cylinders come with the ports?
  12. I have a set that I would like to trade But if you make an offer I will probably sell them. They are the bare pipes no dents, should clean up nicely. If your interested I will email you pics. Jeff
  13. where are the intake ports I looked at the jugs and see no where to put the lines, I have a lot of money in this thing and all i want to do is ride the thing. Ive been messing with the thing for a few weeks and am getting pissed that It doesnt run, But the hose problem would make sense. any and all information would be great, the guy I got the jugs from didnt give me directions so Im kind of in the dark.
  14. Ill trade you my paul turner mid range pipes and some money, I can send you pics if your interested. peace jeff
  15. The hoses just go on the powervalves and then point down to the ground right? How can the hoses do so much? Is there a certain length that they work best at?
