All_Out_0606
Everything posted by All_Out_0606
wow no one???? plz..?
well im bout to get this motor back in, this is what it has. Wiseco Crank (stk stroke), wiseco .020 pistons, white bros boost bottle, k & N, FMF gold series fatty headers, with power core 2 silencers. The jetting that it was running before the oversized pistons and crank and running in the warm weather (75-85 degrees F) was a 290 main, not sure on the pilot. Should i just bump it up to a 300 or 310 main now with the bigger pistons and it getting colder outside? (40-60 degrees F) im at 800 ft above sea level. and you already know what i got and temperatur. thanks for the help. and how much more on the pilot if any.??? recommendations?
ok kool thanks guys, imma get those cases back together soon, if i need help, ill ask you guys, and im going to follow your guide bigred, this kid has no idea what hes doing, i do, if itook it apart, but when he tried to put 4 washers onto the idler gear i was like, aaaaa ill put it back together, thanks anyway. ill take pictures if i need help, thanks again.
well i went and looked, it looks like im not missing that one clip, but just to make sure, how many of those clips are there???
ok thanks for the help, now i know im only missing one, i wonder where i could get one??
anyone?? how many, and are the only on the bottom part of the crankcase??
Ok i have my cases split on my 95 banshee, im puttin in a new crank, to make a long story short, i need to know how many of those C clips or whatever you want to call them, that line up the bearings inside the case. they are half moon jobbies, i didnt split my cases, my buddy did, and i didnt see how many there were, i went to put it back together tonight and i kno im missing one. But are there C clips that go on the bottom and top of the case(or bearing) so that they would make an "O"? or are they just on the botoom half of the case? im missin the C clip that goes on the small side of the mainshaft that has 2 shift forks holding it in place.
alright we'll try that, there is already a master link in the chain so ill just take a link out that way, ill still have to do a little grinding but thats ok.... ill let ya kno how it works
well i went to tighten my buddies chain on his banshee, i loosend the 2 side colts so i could move the chain back. Its on the tightest it can go and the chain still have about 4 inches of play in it.........Is there anyway i could take out some links in the chain to make it tighter? He also put a 13t sprocket on, and we goin on a trip on thursday and hes on a budget, he doesnt ahve the money to buy a new chain... Any ideas?
the cabrs have been cleaned, so i guess ill jsut have to pull of the left reed cage and tkae a gander.. prolyl wont be till this weekend, its cold outside
i have a 2001 Banshee w/ FMF gnarly series pipes, White Bros boost bottle, K and N air filter, and jetted with 290 mains at about 800 ft, the temp out is around 40 degrees... ok now my question is... When I start it, i pull out the choke and kick it about 2 - 4 times and she startes right up, but sometimes it runs on only the right cylinder. Ill take off and it does its normal "im cold, so i have no power" run, then as soon as it gets warm, it runs fine... but if pull u some where and stop...and let it sit for a few, itll run on the right cylinder and bog at low rpn until i get the rpms up then both of them kick in, and theres all the power. also if its jsut runnin on the right cylinder, if i pull the choke out the left one starts to run fine... any ideas why it does this???
Ignition Problem... No Spark... Where do I start?
All_Out_0606 replied to jbes3's topic in Banshee Repairs and Mods
i jsut fixed my buddys banshee that wasnt getting any spark, happens to be that the orange wire going to the coil was unplugged, make sure its plugged it and the black ground wire. check ur spark plug caps, make sure they are screwed into the wire nice n tight. If those are both good. then you probably jsut have a bad coil.. also check and make sure your kill siwtch is on lol not calling you dumb, but hey you enver kno haha, hope this helps.. -
All right I GOT IT RUNNING PERFECTLY!!!! YAY!!!! ahahahaha, come to find out, my slides were set way to high, so i set them all the way down, and adjusted the golden idle screws, and it runs great now, thanks for everyones help!!!!! couldnt of did it with out you guys haha...
lol how you kno which way is in right and which way is in backwards?
this will give you an idea... http://photobucket.com/albums/y174/All_Out...rrent=Carbs.jpg i plan on checking everything tomorrow..
yea they are closing, but i did mess with the caps that go ontop of the carbs, (one at a time) would that do anything???
ok well i figured out my problem, the orange wire that goes from the CDI box to the Coil was unplugged... so i put a new connection on it, and it started right up. But now it revs really high!!! it wont idle it just wants to blow itsslf up. I made sure the choke tube connected, i made sure the carb clamps were good and tight, both slides are opening up at the same time, i tried screwing the idle screws all the way out, it would rev high then go back down in rpms, then jump back up kinda high, then id try to screw them in and it jsut started revving like crazy.... so i dunno whats going on.... plz help
My buddy has a 1995 Banshee, and today we went riding and it was running fine for a few minutes, then all of a sudden it started bogging on the low end, then back firing really bad when id rev it up. we put in new spark plugs, and the fuel is brand new, mixed at a 40:1 Ratio. I dont have a clue whats rong...? Any ideas? We need this thing fixed by sunday, cuz were going on a trip. Im also not getting fuel into the motor.... Itll run when i spray carb cleaner into the intake. It will run until it runs out of carb cleaner... There is no TORS, i am getting spark... It has FMF fattty series pipes, jetted at 290 main stock needle and pilot i assume, milled head (.030) and im not sure on the fuel/air screws, i need help setting those cuz we messed with them. BUT that was after it started acting up. This thing ran fine like 2 days ago...it also has a UNI filter, which the front of the filter was wet with gas... but could any one you banshee gurus help a new comer out?! plz thanks in advance... ill post anything i forgot, or if you need more info ill do my best... one more thing. I took off the carbs sprayed them with cleaner, took off the bowls (one side at a time) and sprayed them... so im running out of ideas...
