I was riding my banshee one day and the Water Pump, Bearing, and Seal all went which created water to get into the oil this was not the problem since I imediatley found the problem but Why did this happen?? Im sure because it overheated and blew the seal which then blew the bearing and pump. It is a aftermarket water pump made by pro designs.. This is what the quad has on it...
Powdercoated frame, T-5 Pipes, TCS shocks front and rear, RPM -1 swing arm, RPM steering stem, RPM 2+2 Axle, Pro Taper Bars, Timmy Boy +3 A-Arms, Duncan Bumper, Steering Staybilizer, Hinson Clutch Cover, Trinity 2 into 1 carb, V-Force Reeds, Vito's 8hp Pistons, Vito's Hot Rod Crank, Aluminum Stator Cover, Pro Design Shifter, 2 In line coolers, Pro Design Water Pump, Baja Wheels, Rear Brake Cooler, a New Top End, oversized radiator and is bored out to 202 and 202 equalling a 404. It needs a bigger needle in the carbs but right now its tuned to the point where it is running fine or was.
I use to run race fuel in it and I was told to go back to race fuel because that will keep it cooler, Im not really sure what to do but I really dont want this to happen again.
ANY SUGGESTIONS.... Thanks!
