Hello, My name is Kai and am a off road enthusiast. I like bikes quads and trucks. If I didn't buy a YFZ 450 then I would have a Banshee for sure. I do have a question about a RZ350 Power Valve. How can you tell if it is indexed correctly. I suspect (hope) that it is 180 degrees out. The bike runs well but just does not scream like I believe it should. It is an 85 RZ350 Kenny Roberts. It has new pistons 30mm carbs with dynojet kits, a 2 into one air filter and old Spec II chambers. The previous owner also installed new reeds. I do not believe it was ported or modified other than that. I am hoping that the power valve is installed incorrectly. It does cycle with the ignition and the pin hole aligns with the notch in the cam. Can someone tell me how to tell through the exhaust port if the valve is indexwd correctly. Thanks! Kai
