Everything posted by peterlocal22
need a new front headlight right side for my banshee?
cant get the cluch line off my clutch hand lever
peterlocal22 replied to peterlocal22's topic in Banshee Repairs and Mods
couldnt get it off so i cut the lever at the insertion point of the cable. needless to say it fell right out. fit in the new lever and now im ready to go. thanks IROOST1 -
hello, i bought a new clutch hand lever and cant get the cable off the original lever. seems like theres a hockey puck shaped piece of metal at the end on the line that needs to be removed. are there any tipe of c clips holding it from coming off? i have to get this stupid lever off and the new one on so i can go riding this weekend. any help is appreciated. thanks
whats up everyone? i bent my steering stopper and im haveing trouble bending it back. any advice? also do i need to reweld it after i bend it back or is it ok. thanks
ok you guys talked me into it. im keeping the protaper bars but i need to find a new spot for my ingnition and key. give me some ideas. i know alot of you have it hidden in some pretty cool spots so help me out. pics would be great and any tips are welcome. thanks for always helping me out peter
needs some help w my pro taper med atv handlebars
peterlocal22 replied to peterlocal22's topic in General Banshee Discussion
i would like to keep the stock key set up. if i bought the higher bend would this make a bigger space between the pad and the bottom bar were it mounts to the bike? or does the space stay the same but the bars go higher? thanks -
whats up everyone? i bought some pro taper med bend bars for my banshee. i took the old ones off put new one on but the pad is rubbing against the key and the plastic box that surrounds the key. should i buy the high pro tapers or can this be fixed. as it is right now it looks like everything is squished together were the key is located. as it sit right now i cant move the bars any more forward. thanks for any help i appreciate it.
could u add me? thanks
whats up everyone, have some new handlebars coming but want 2 new levers to match? any advice? what do you guys like and how much are they pics would be great thanks
if you could email [email protected] with pics that would be great thanks
just wanted to try a new set of handlebars and wasnt sure about the bend. what do you like best?
looking for some nice aluminum handlebars but dont want to spend over forty bucks. any recomendations and bars to stay away from. any pics? thanks
bump
those look pretty cool and thanks for the help. the only thing is im looking for the gullwing on the a arms. anymore help anyone??? thanks
2004 Polaris Predator 500 Troy Lee Edition
peterlocal22 replied to Supergumby5000's topic in For Sale - Parts & Accessories
i know some one that might be int. do you have pics? -
if you could send pics to [email protected] thanks
im hoping to get there for the 28th but it depends on work
NEW AIR BOX W/PRO DESIGN INTAKE
peterlocal22 replied to apbt549's topic in For Sale - Parts & Accessories
hello can you send a pic to [email protected] thanks -
ill pm you tomorrow about some stuff
whats up everyone, im looking to buy a long travel kit for my banshee. looking for whole kit or just a arms just shocks, etc. let me know. pics would be great send them to [email protected] i have cash in hand
Whats up pal? Ive run into this same problem a number of times. Most likely no water got into your system but you should change the transmission oil just in case to be safe and to make yourself feel better. If the oil is milky like then water did get into your system. If this is the case you should change the oil twice. You should also probably clean your air filter box and filter. One more thing that I found out the hard way. Take your bike out side in the back yard or over some sand. Put it in gear and switch the gas to off. Lift the nose up, all the way until you can rest it on the back grab bar so it looks like its doing a wheely. Let it sit there for about fifteen minutes. Make sure you watch it for a couple of minutes to make sure there are no fluids leaking. However you may see some water, might be rusty color coming out from pin size holes in your frame. This is water build up with in the frame that needs to get out other wise it will rust out your frame from the inside out. Let it all come out. The banshee frame has alot of little holes through out it at differnet weld points. I have noticed when i go through water that water enters through differnet points and sits inside the frame until its removed. If you want you can take out the pegs and those two holes were the bolts go in are the bottom of the frame and thats usaully were the water will reside. Dont be affraid to squirt some oil in those holes before you bolt the pegs back on. This will help protect the insides of the frame. Anyways I throw my bike up every time after ive encountered water. I do it when im done rideing that day and for a couple days after. I hope this helps and if you need any more help dont hesitate to pm me.
hello im int. can you send pics to [email protected] thanks
looking for some rocket pipes will pay top dollar for them thanks
whats up everyone, my buddy flipped his banshee over the weekend. luckily hes ok but the quad is not. any one else done this? he was riding up a hill pretty fast and went off the side were it dipps down like a stream use to be there and then into the woods. the bike was found upside down on a rock. what do i need to to look for? so far the two a arms have some dents , the steering is messed up. when you steer all the way to the left the tire hits the a arm and almost the pipe and the tire seems wiggly. the tie rods and ball joint are gone. the left pipe hanger broke and the left pipe dented and twisted a little. The pipe was pulled out of the pipe clamp and silencer. the cluch lever is bent, there are stress cracks on the frame were the steering stem comes in. the part that stops the steering stem from turning too far is cracked. theres also stress cracks on the arms that hold the rear plastic. the right head light is cracked. we started taking it apart today but he got a little upset so we stopped looking but will resume tomorrow. any help, advice or similar stories would be great. thanks peter by the way for any of you who know him his name on the site is vitovito240 so hit him up if you can help or post here thanks
