Robert
Everything posted by Robert
anyone know how i should install my subs
Robert replied to sweetshee4312's topic in General Banshee Discussion
underpowering is not good at all, my HCCA 225 thats on my subs is bridged down to a 1/2 ohm. 1100 watts RMS under rated power. Peak its around 2000 . If your amp is capable of going lower then 4ohms you will notice a increase in wattage as you drop ohms. say 100 watss @ 4ohms would be 200 @ 2ohms, 400 @ 1ohm, 800 @ 1/2 ohm. Most of the newer amps i have looked at only go to 2ohm. Get a competion amp and drop that baby down to 1/2 ohm and notice the difference. Fosgate makes good amps. You just cant drop the ohms too low. I blew a punch amp dropping it to 2 ohms. Your system is alot like your banshee. put a little money into it and get quality parts/components and it will last a while and perform good for you. -
Thought this quotation will be good for people constantly trying to argue against ignorant people on forums: http://www.quotationspage.com/quote/23566.html
http://www.dailytimes.com.pk/default.asp?p...7-12-2005_pg9_5
Counter-Strike.......I Need Help
Robert replied to Rookie_of_the_year's topic in General Banshee Discussion
If you dont have a cd key, its best just to buy the game. All the pirated cd keys that you will find on the net will already be banned from general play. I like free games as much as the next guy, but to play multiplayer on the net its best to buy it so you dont have to worry -
you will need a cd key for CS to play. I play some cs source every now and again. -
This thread should be closed.....
as long as you have a cd key for the game you can register for your steam account. http://www.steampowered.com/index.php?area=getsteamnow -
http://video.google.com/videoplay?docid=-7193470719293309352 I thought it was very creative
I personally didnt get much, some money, socks, dvds, and a few other small items. I didnt expect much tho. My little girls made out good, Lots of Disney princess shit, i think just about everything to do with disney princess =/ once you get to a certin point in your life its not about what you get, its about what your kids get They were happy, me and the ole lady was happy So all in all it was a great christmas.
All depends on the make of the amp. My orion amps are only rated at 50watts x 2 @ 4 ohms. the HCCA amps are capable of going down to a 1/2 ohm. at a 1/2 ohm its pushing around 1100 watts. very very clean watts. I can push 4 12's from each amp easy and would sound as good as a 2000+watt amp. They call them cheater amps for a reason you get what you pay for. JL makes good subs, I would push them with a old school orion or mmats amp to give them a good deep thump of pure watts. Most of the newer amps and off brand rate their amps at peak power, so if they say 2000 watts or what ever, its probably only kicking almost half that in actual RMS watts. I would take a Orion HCCA 225 rated at 50watts x 2 over almost any 2000+ amps on the market today. Set them JL's up with the right box and the right amp and your friends will have no problem hearing you come a few blocks away -
821.7 on like my 10th try. This game has been around the internet for a while, I have seen a few different versions of it.
I would go with a aftermarket H/U and a Multi-channel audio processor so you can run all 8 speakers. Im not sure about all line converters you splice in, but one that I seen had a 250 watt limit or around there ( I could be mistaken). Im running 2 12' kicker solobaric L7's running off a orion HCCA 225. I also have all my mids running off another HCCa 225. All off a pioneer H/U. Sounds awsome. I have a alpine audio processor but am not using it right now. Im planning on installing it again monday You cant go wrong with a good setup. start splicing wires to convert signals then IMO it takes the quality out of it and makes weak links. If your running JL and whatnot, why shove walmart shit to run with it -
I noticed it was deleted as well. Its always fun reading retarded posts.
I have a set of stock shocks I could let go pretty cheap, say $40 plus you pay for shipping. Let me know if you want them
I have been using Fly Grips for a few months now and have had no problems, no glue needed Check them out here
This site has no banshee shirts of any sort that i have seen, but they are awsome shirts none the less http://www.tshirthell.com/
What he said, plus make sure your kill switch is turned on...
IMO, Taking perscription pills is like painting a rotted fence, It may look good from the outside, but its still rotten on the inside. My only advise is confront everything thats bringing you down. Solve each problem and go on with your life. Everyone feels depressed every now and again, its how we deal with it that makes a difference.
Yeah your probably asking too much for a bike with no title
I had a similar problem not to long ago, only would spark like one out of 100 kicks it seemed. i replaced the coil, cdi, and was about to do the stator. I wound up disabling the TORS and it ran perfect after wards. Is your TORS still hooked up?
http://www.bansheehq.com/forums/index.php?showtopic=52220
I used a jigsaw with a fine tooth aluminum blade on it. used 400 grit sandpaper to finish it off. turned out real nice, no cracks or imperfections so to speak.
what kind of mods can you do so you dont need to use the clutch?
Never heard that before, and dont think I would try it.
