i was wondering if anyone knows if u can juice a banshee? and if i could where to get the stuff i need, i have a full kit for a streetbike, but idk if i can use anything from it , any help would be appreciated
i was just wondering if there is any difference on aftermarket heads, i have a 420 big bore kit 39 mm carbs boost bottle k & n airfilter and just want the best heads i can get
i have the dmc exhaust same one on mine i have a 420 kit big bore carbs boost bottle or whatever u call it and a few other things and mine is wicked fast and sounds sick i would definitly go with the dmc
i have a 2000 banshee with a 420 kit and big carbs and boost bottle, it has dmc exhause that goes 2 into one is this a good exhaust? im kinda new to the banshee thing so if anyone could help and let me know if there is a better exhaust
i pulled them back out and on the end of the needles they look like its grooved from where it is supposed to seal on the seat u think thats the problem, bye the way thanks for the help
does anyone know if the muffler packing is blown out you loose power? i suspected it cause its goddamn loud i have a dmc exhaust i pulled the back cover off and nothing inside of muffler can someone help me please
to help your cooling problem first thing is take every cooling hose off, sounds like a pain but do it , i had the same cooling problem, and just check and inspect every last inch of all of them, then replace the cap they are cheap enough that just incase it could be part of the problem and definitly check your overflow hoses and tank oh and check your waterpump it could be not working correctly
thanks but when i took the carbs off the floats were moving perfectly fine, do u think it could be hangin up as soon as the bottom case is on it? tryed tapping it it doesnt work, and does anyone think it could be the needle and seat?
my banshee wouldnt idle b4 , it was sittin for 6 months, i just took the carbs off and cleaned them out everything looked normal , now it idles , but when u turn it off it leaks gas out of the bottom bowl overflows, both carbs anyone have any ideas?
yeah they had carbs but i never had to mess with 2 carbs you dont have to be a smartass dude just asking your opinion and will i have the same power with a single carb kit?
i have a 2000 banshee , it has a 420 kit , dmc exhaust big carbs, boost bottle , and it does not idle it hasnt been ran for 6 months and im just wondering if anyone knows if it could just be some junk in the carbs thats makin it not idle? i appreciate any help
my banshee has a 420 stroker and idk if there all like mine but i dont really have that much low end my power kicks in at mid and high rpm it pulls wicked hard tho when u get the rpms up
