Superman
Superman's Achievements
  1. Planning a trip from kansas to St Anthonys for labor day weekend. I thought about going to Little Sahara Utah since I'll be so close. Whats going to be the best place for the weekend, LS or ST anthony? Also any info about them both would be great.
  2. I have had very good luck powder coating Yamaha A arms. The trick is heat absorbant paste. First clean and totaly degrease the arm and ball joint. Then take aluminum foil and make a cone or funnel around the ball joint. You can use safety wire and wrap around the ball joint in the same grove the stock clip uses. Once you have the cone built you need to pack it with the paste, maybe 1/2 ounce per ball joint. Don't overbake I have coated arms with both single and double stage powders and havn't melted a bushing yet. The paste I use is something like Thermopaste I get it at a local HVAC supply company. Be sure that you leave the arm upright when curing it other wise the paste will try to melt out. Good luck and don't settle for non coated a arms its very possible.
  3. I charge $125.00 to powder coat a banshee frame, it must be blasted. Let me know if I can help. Mitch
  4. I have sucessfully powder coated Yamaha a arms without harming the teflon bushing inside the ball joint, I use a heat paste to absorb the heat and it works great. Let me know if I can help.
  5. Wondering if I can port my cylinders and still use my vitos super stock pistons. I just had them bored and installed maybe 4 hours on motor, thats why I hate to buy new ones.
  6. Amyone ran ultimate 2 if so is it worth the 10 bucks a gallon. I ran the ultimate 4 in a R6 and added about 15hp. Just wondering if it works that good in a banshee. I know has oxeygen in the fuel so you have to richen you mains up but how much?
  7. Want to buy a ricky stator flywheel with the good magnets. Does any one know if you can lighten them.
