nsoron
Everything posted by nsoron
  1. I'm looking for a set of upper arms, doesnt matter what year, with blown ball joints for a project i'm working on. I dont have much to spend, looking in the 40 shpped range for the set. If anyone has some, please let me know. Ron
  2. I had a similar problem, but mine ended being that I had a bad sealing surface in my cases and had a leak. I had to do a leak down test to trace the leak. This leak caused the cylinder to lean out/suck transmission oil into the cylinder and then detonate. Eventually running with it like that caused me to hole a piston. I would check the other electrical things first especially the harness if its hacked.
  3. I am looking for these tires since the company went out of business and I need another set for this years riding season around here. Let me know if anyone has a set, preferably new or very little use near area code 18201. I am in Northeast PA.
  4. Make sure that those banshee pistons you ordered are for the long rod crank because chances are if blaster pistons were in there before, the crank is the +5mm long rod. Putting in regular banshee pistons would result in the piston colliding with the head which isnt a good situation.
  5. This also includes a brand new never used twist throttle setup and cables. Pictures are also available.
  6. I have a set used Kiehin carbs for sale which have only about 3 hours on. The only problem is someone lost the jet change plug then tigged an aluminum plug into the hole. I would like to get 175 for these carbs and that inlcudes a set of pod filters. Shipping will be dtermined on location.
