I'm looking for a set of upper arms, doesnt matter what year, with blown ball joints for a project i'm working on. I dont have much to spend, looking in the 40 shpped range for the set. If anyone has some, please let me know.
Ron
I had a similar problem, but mine ended being that I had a bad sealing surface in my cases and had a leak. I had to do a leak down test to trace the leak.
This leak caused the cylinder to lean out/suck transmission oil into the cylinder and then detonate. Eventually running with it like that caused me to hole a piston. I would check the other electrical things first especially the harness if its hacked.
I am looking for these tires since the company went out of business and I need another set for this years riding season around here. Let me know if anyone has a set, preferably new or very little use near area code 18201. I am in Northeast PA.
Make sure that those banshee pistons you ordered are for the long rod crank because chances are if blaster pistons were in there before, the crank is the +5mm long rod. Putting in regular banshee pistons would result in the piston colliding with the head which isnt a good situation.
I have a set used Kiehin carbs for sale which have only about 3 hours on. The only problem is someone lost the jet change plug then tigged an aluminum plug into the hole. I would like to get 175 for these carbs and that inlcudes a set of pod filters. Shipping will be dtermined on location.
