TySk8er8808
Everything posted by TySk8er8808
  1. banshee forsale or trade for a 250r motor: lots of ported work, advanced timing plate, V force reeds, 30mm carbs, k&N filters,vortex clutch basket and barnett clutch, hotrod crank, stage IV head with 18cc domes, Dyno port pipes and t5 exhaust, Frame: its a 87 j-arm frame with works shocks,+ 6 inch extened swingarm,+4 durablue axle, twin row dura blue alxe carrier, brand new sand tires, brand new flat black plastic i will also trade for a newer dirtbike
  2. would u trade for a tricked out banshee
  3. okay i just bought a brand new clutch basket from vortec and new barnett clutch i was wonderin what is the correct way of ajustin the clutch, cause i went to silver lake last weekend and all it was doing is slippin, the motor was revin but not going no where. also iam on runnin 5 out of the 6 barnett springs cause they are so stiff would that make any difference
  4. another question what should me timin be set at, I got it at +5 right now
  5. okay I have question, I just bought 18cc domes before that i had 21cc domes i did a compression test before i installed the new domes it was at 150psi after i changed the domes to 18cc and new O-rings the compression was at 210psi, is this normal to be that high and how much of a power difference will i notice.
  6. I was wondering if you would take 50 for the clutch basket since its got a little play, also how would i send the money through paypal or money order
  7. I got a set and they work greattttttt.............
  8. send the pics to [email protected]
  9. I was wondering if anyone has a stock or aftermaket clutch basket for sale..........
  10. Anything, just make offers.....
  11. i got a 94 Cr125 with new plastic i want to trade it for some high performance parts for a banshee, if interested make some offers..............
  12. I bought a aftermarket CDI few weeks ago off ebay brand new hooked it up and does not work the only wire that I did not use is the green wire with a yellow strip, I was wondering if anyone knew anything about that wire or possible why its not workin....... http://www.procomengineering.com/ is the brand of the CDI has anyone used one
  13. I will be there toooooooo mon-fri
