Everything posted by Mxjunkie69
I'm in a little need of help, I recently tore my Banshee down for a rebuild but of all thing's I cannot remeber how the kick starter mechanism goes into the case.. I've sat there and fussed with it for a little and can't even think of a way for it to go, Any help would be great I'm sure it's something easy and I'm just being a stoonod at the moment lol..
Banshee, tranmission filled with anti freeze
Mxjunkie69 replied to Mxjunkie69's topic in Banshee Repairs and Mods
I'll check that right now. -
Thanks for the fast help guy's I guess I'll have to rip the motor out this weekend and have another project to do! :biggrin: -
The motor is a 99, the cases were spilt about a year ago because a couple shift forks in the transmisson needed replaced. I cracked the clutch side case at a PA state harescramble 2 months ago and bought new side case, new billet water pump propeller and all new gaskets as far as the sidecase goes. I am hoping it isnt anything that requires spilting the cases I dont have that much to spend at the time being but if it is I guess I'll park my baby and fix it over the winter.. I've herd mixed opinions on what it could be, many have said head gasket, some have said a cracked case or water jacket. The seals going bad sounds like a good thing for me to check. I have the clutch sidecase off now and doesnt appear to be any cracks in the cases and the oring the kid just said seem's to be in good condintion. One thing I have noticed my coolent over flow bottle doesn't stay full. -
I was recently riding my banshee and I stopped to take a beather, I noticed fluid pouring from behind my front sprocket! The seal was blown out and there was a mixture of anti freeze and transmission fluid pouring from it. I pushed it home and drained the transmisson and it's full of anti freeze.. Has anyone ever had this problem?
I'll deff look into it, it is a 97 so I was also considering buying a new coil for it but anything I can fix and not spend some money is wondeful :biggrin:
Well guy's I have some sort of eletrical gremlin that keeps appearing every couple weeks for some odd reason! I was out riding today praticing for a cross country race tomorrow, I wasn't in any water or mud. I was coming into a turn and my banshee suddenly shut off completely, I couldnt get it to fire back up so I pushed it a mile through the woods to my house, I found a buddy with a truck and he towed me back, as he was towing me I tryed to jump start it with no such luck! I got it home and I checked to see if it had spark and there is none I've checked every connection and cleaned them throughly I cannot understand why it's doing what it's doing! The t.o.r.s was removed 2 years ago and the black box under the tank is gone etc.. It's been running for 2 years fine until recently! :verymad: There's gotta be someone out there with the same problem :shoothead:
Hey how much is the frame shipped to 19311
I just went out and looked the ground wire ripped off I guess I need a regulator now afterall... damnit.. I guess a tree branch got it when I was up at breezewood or something and when I was riding at the house it finally let go..
lol I'll look at it, I remeber someone telling me it might be the silver box by the cdi for some odd reason..
I went to go take my banshee out riding tonight and when I hit my light switch the lights worked for about 10 second's then stopped.. My tail light doesnt even work. The bulb's are fine and I went over all the wiring and it seem's fine.. Whatcha guy's think is wrong?
The 27.5 pilot's did the trick! idle's perfect now I just have to drop the needles one in the jet's and it should be good to go! Thank's! :beer:
Yeah it has the airbox lid on sorry for the late reply just got home from work
That's what I was thinking as well but when I brought the needles one clip up out of the jets it ran alot better.. This quad has been a pain in the arse my shee is easy to tune compared to this thing ::
I'm having some trouble's getting my cousins banshee tuned.. It has 260 main jets, fmf needles on 2nd to last postion stock pilot jets and air/fuel screws at 2 turns out.. It has boyseen reeds, 10mm reed spacers, uni air filter, we just put a pro design timing advance plate set at 4degrees, t.o.r.s removed and fmf sst's with powercore 2's It starts first kick but dies instantly unless you have the choke out, wont idle and if your riding it lowend it wont run unless the choke is out.., mid-top is fine It's sounding like it needs bigger pilot's but I thought it would be a good idea to come on here and ask before I go and buy them! Whats the next size up 27. 5's?
I did a search and it has nothing like mine, and it allways has some idiots having a conversation..
Anyone?
my cousins banshee is about as bad as mine is lately.. His has a k&n filter, fmf fattys, powercore 2 silencers, boyseen reeds, and I belive thats it. Lid is on the airbox. snorkle removed, fmf boost bottle, b8res or br8es I forget which ngk plugs. I live in PA, its really cold around here at the moment, it had 260 mains in it but it wouldnt idle or anything.. we put 250 mains in it and put the clip in the center position, bogged down pretty bad in the low end, leaned it out with the clip it hit the top still did it. we put 240 mains in it, tryed center, still did the lowend thing, went all the way to the top once again, it still does it. It idles pretty fast too, before it wouldnt idle at all and smoked like a train. to explain to low end hesitation, say your riding it, it wont do anything till about mid it just bogs down and doesnt go anywhere, it pulls like a raped ape top end though.. Do I have to move on to a 230 main? the plugs come out black they are getting better though, getting the vanilla chocolate color to them. between my 409 and his mine has ruined 8 sets of plugs, his is on 4 so far.. One plug fouled and it ran home on one cylinder, then it came back, then the other fouled, soo as you can see its been a pain in the ass.. Any help would be great me and him are pulling our hair out trying to get our bikes right!
What is the stock jet size in a banshee, and where is the clip placed..
First time, it acts like its to rich.. Just wondering what is the stock carb jet size and needle position? My cousin is having problems with his now lol
409 stroker motor, vitos crank,mikuini 35mm carbs, fmf fattys/powercore, k&n filter, boyseen reeds,2mm off the head, wiesco pistons, port/polish intakes and exhaust..
I recently had to take my banshee motor out due to a tranny failure and I got the motor back tonight, put it all back togather went to start it and here are the issues so far.. It will not idle.. Wont rev high.. Smokes like a train.. I'm thinking it needs to be tuned because of the colder weather but I have been wrong before so if anyone can help me it would be great.. thanks
Mine did the same thing expect mine broke the gear selector spring thank god
Will do, Its just been rattling my head and I was quite upset when I saw no spark
I know this is not where you post things about your banshee but guys I am pulling my hair out, I traded a 2002 cr80 for a 99 banshee got it home, checked it out it was blown up bent frame etc, I have spent almost 5 grand on it and fixed it, had NO spark, put a new stator, timing plate etc. it HAD spark in my house. 2 weeks later I get it out of the house it now has NO spark! Please help!
