vwpartsman
Everything posted by vwpartsman
  1. You should call casey he might want it
  2. You would have to have the cylinder milled down to fit the 4 mill crank to make your port timings come out right. So yes it could but not like it is right now
  3. $750 and you have a deal
  4. Topend is for a 7 mill stroke and its at 72MM bore which is the bore when you get them. lots of life left in the liners. I'll pass on the $500 offer
  5. I have a complete Banshee 7 Mill topend Comes with v force 2 reeds, rubber intakes for 40MM carbs, head, domes, cylinders, pistons, and all nuts and bolts and orings for installation Has had new liners put in them with 1 weekend of racing so the bore is 72MM. Ported by packard. Setup for alcohol Everything is polished. Best time was 3.81 One piston looks like it has a minor cold sieze on the intake side of it. Was running when taken apart so you could run it like it is or replace the one piston. $850 shipped
  6. Has not been used since being polished $50 shipped
  7. I have a complete engine that I bought to run in my bike but since have a falling out with Twister and I don't want to represent there product. 8 mill stroke long rod Twister billet crank 75MM bore big block billet cylinders with power valves 550CC straight cut gears Billet basket Stock tranny Lockup with polished cover Billet stator cover Adjustable timing plate with stator Powdered caosted cases that were bought new form Yamaha at the time of the build 38MM Keihin PWM carbs CR 125 reeds and cages Engine comes with everything but shifter, kickstarter and pipes Motor made 108HP on Twisters dyno I tore it all apart for inspection when I bought it and thats how it is now.....you can buy it all apart or I will put it back together for you. $3000 shipped for it all This is it when I bought it all together... All polsihed up now Both covers
  8. Hard to see but its right at the bolt The other one is just the towel folded and a smudge on it.
  9. I will take one tonight it goes from the bolt hole stright towards the middle and its about 1" long
  10. Just polished and comes with the cover, lockup, and blue see thru cover. One crack in the cover but doesn't leak. $300 shipped
  11. What tires are you running? Will make a big difference if there 20's or 22's and how many paddles?
  12. I'll still take them. Won't be back on the rest of the night. Send me the paypal address and tomorrow I'll get the money off to you
  13. sent you a pm for the rear brakes
  14. I'll take it whats your paypal address?
  15. Freshly polished rear brake caliper $100 Polished 35 PWK's $325
  16. I have a freshly polished one for $60 shipped
  17. I'll take them for $100 shipped
  18. I have a nice set of unstamped small bore CPI inframes with polished silencers and billet clamps in excellent condition $475 shipped
