road racer
Everything posted by road racer
  1. The o rings broke in half. Mine leaked around the studs too until I put sealer around the washers.
  2. o rings broke during usage and leaked coolant. Not sure why.
  3. I have a mod quad cool head with pro design domes. I am having trouble with the outer o rings breaking. Will pro design o rings fit it or do I have to find more mod quad ones ?
  4. Someone must have tried a set if hi-revs ? What did you think of them ? I have mids now but am looking for more top end without giving up all the low end they have .
  5. How much more top end does the hi rev have over the mids ? Do they give up much low end ? What pipes do they compare to power wise ?
  6. They have a slip joint on the expansion chamber and you can change the length, and by doing so changes the power curve.
  7. Thanks. It's good to hear some positive feedback.
  8. Thanks Ducman. They will be going on a 4mm stroker with port work. I also have a set of PT mids to try on it. Should be interesting to see which performs better when I get it back together.
  9. Does anyone use these or did I just buy some more shiny crap for the corner of the garage ?
  10. Just picked up a set. How do they compare to other pipes like fatties or t5's . Where should they be adjusted to for best performance? I have had fatties , t5's and some PT mids (have not tried yet) just wondering what to expect. thanks
  11. Still have the head? Does it come with studs ? How about 125 shipped?
  12. What bore size are the cyls. on ? What do they have for pistons ? What else is needed for this to be completed ? Do the cyls come with exhaust flanges? thanks
  13. Mostly trail riding with alot of wide open woods roads.
  14. How much of a power increase will I get if I go with a Vito's 404 big bore as compared to .020 stock bore with similar port configuration with a +4 stroker crank ? Is it worth the extra cash ? thanks
  15. Going with +4 stroker and long rod with 795 pistons. Where can I get a cly base spacer approx 2mm . Does wiseco sell them or is their's a head spacer? Vito's has them, not sure which one . thanks
  16. Has anyone tried the dynoport twins ? What do they compare to power wise ? Top end pipe or good all-around?
  17. Would a set of t3 pipes be a good choice on a +4 stroker engine with stock type cylinders? What other pipes would be a good choice? Don't want to cut front fenders to make the pipe fit. thanks
  18. I am interested in the crank. Is the basket gone as well? I sent you a PM. Please reply or PM me. road racer
  19. Sounds like what I might be looking for. What pipes and carbs are needed for that ?
  20. The majority of my driving is trail, woods roads with some pavement dragging for fun (bragging rights). Don't want a full drag bike just a fast one with low end balls.The last one would do 90mph on radar, looking for more.
  21. Thinking of building up the shee for more power. Last one had mild porting with t5 pipes,shaved head and +4 timing. Looking for more. How much increase will I see with a stroker +4 set-up and pipes (fatties or t5 not sure yet) ?Is the spacer plate the best or a modded head? Do mostly trail riding but some road dragging. Looking to kick some ass bad.
  22. Just read an older post on jetting. Are the Dynojet 340 mains different than Mikuni 340 jets. If so are they bigger or smaller? Thanks, roadracer
  23. Are they worth it? Has anyone tried the GYT box?
  24. Will the rear axle from a raptor fit the banshee? My banshee has the shakes at speed from a slightly tweaked axle. I can get one from a raptor cheap. Will it work? Thanks. road racer
  25. Is it the tors that causes the stock carbs to stick when wet or something else? It is very annoying and if possible I want to cure it from sticking. Does the trinity 2 into one improve top end more than stock or maybe a set of 30mm keihins?
