yan
Everything posted by yan
  1. alot of money
  2. what is an outerwear and what dose it do also when people say that they run with no air box does that mean there is no box at all and the filter is just out there if the filter is just out there mud water and sand must get every were
  3. thanks so i have to rejette or take off the tape and ride i will leave the lid on without the lid there will be too much sand coming in from every were
  4. i alreay posted this under another post put if i wasent brain dead i just would of posted it here i have tr6 pipes and the pipe set comes with a jette set and 12 of these little 1" air hole things so the shop jetted my shee acording to the air intake with these little 1" air hole thing that is put into the air box for more air intake and there is 12 of them so i put tape over the holes and it stop some air intake and it realy made a differance it got slower i know that it is normal but do i have to re jette or what my banshee semed to get hotter than usual is that bad that i cover the air holes like that
  5. i know i have to clean the air filter alot but i am running a pro design pro flow air filter and the outer red fiter i some what pretty dirty so i guess that the yellow filter that is under the red one would be dirty so my question is that would it take alot of sh*t to make it through the both air filters and get in side the motor so would i have to clean the air filter alot (within reason) i have tr6 pipes and the pipe set comes with these little 1" air hole thing to put into the air box for more air intake and there is 12 of them so i put tape over the holes and it stop some air intake and it realy made a differance it got slower i know that it is normal but do i have to re jette or what my banshee semed to get hotter than usual is that bad that i cover the air holes like that
  6. no one knows or what
  7. as i posted before about my air box and it haveing 12 1" inch holes in it so what i did is put duck tape over the holes so now the only air flow is the lid with no hose on it , i took of the hose part to get more air intake so my other question is that i have toomey tr6 pipes and a pro flow pro design air filter and when i blocked the holes i felt less power and the sound is not the same i know that is normal because there is less air intake but with my mods and the way that my local shop jetted my banshee for the pipes and the air intake, am i going to have to re jette it or something because there is less air intake the motor got realy hot not sure if it was hotter then usual but hot is the stock air flow enouf for my mods and so i am not going to over heat or mess up my motor in any way any help please
  8. as i posted before about my air box and it haveing 12 1" inch holes in it so what i did is put duck tape over the holes so now the only air flow is the lid with no hose on it , i took of the hose part to get more air intake so my other question is that i have toomey tr6 pipes and a pro flow pro design air filter and when i blocked the holes i felt less power and the sound is not the same i know that is normal because there is less air intake but with my mods and the way that my local shop jetted my banshee for the pipes and the air intake, am i going to have to re jette it or something because there is less air intake the motor got realy hot not sure if it was hotter then usual but hot is the stock air flow enouf for my mods and so i am not going to over heat or mess up my motor in any way any help please
  9. i already post about tires and got ok responses but what size should i get i dont realy race and never been to a track i need good groung clearance and also want to go realy fast what is the size on the stock banshee tires so what size for good ground clearance and speed what should i get 6 ply razors or hole shots or .............
  10. the 12 1 inch holes are spread out everywhere....there are 2 on each side, 6 in back where where the plastic coolant container is, and 2 on top of the lid should I ductape them or put cylicone instead?? or should I buy a whole new box and lid??
  11. i have 12 little 1 inch air holes drilled in my air box and i put little air filter like fome inside with a skrin. i have that because i have toomey tr6 pipes and a pro design air filter so my problem is that mud and water get into that dam air box fast because of the little air holes. dose the holes realy make a differance in performance for the pipes and stuff or could i block the holes with cilicone to stop some air flow and some water and mud or realy last resort should i stay away from mud and water altogether thanks
  12. if someone would anwser the dame first time i would not post so many fucken times
  13. yan
    Tires Wanted Help
    i have stock tires on my banshee and i would like to know if anyone has any suggestions on some good all around tires. by all around i mean sand dunes , mud , rocks , gravial trails , grass , what ever and were ever the shee can go, not realy for snow because i am looking at those 4 snow tires. are they any good ? so if any one knows realy good all around tires please write the company or a link to look at or any pictures any thing thank you
  14. i have stock tires on my banshee and i would like to know if anyone has any suggestions on some good all around tires. by all around i mean sand dunes , mud , rocks , gravial trails , grass , what ever and were ever the shee can go, not realy for snow because i am looking at those 4 snow tires. are they any good ? so if any one knows realy good all around tires please write the company or a link to look at or any pictures any thing thank you
  15. i have stock tires on my banshee and i would like to know if anyone has any suggestions on some good all around tires. by all around i mean sand dunes , mud , rocks , gravial trails , grass , what ever and were ever the shee can go, not realy for snow because i am looking at those 4 snow tires. are they any good ? so if any one knows realy good all around tires please write the company or a link to look at or any pictures any thing thank you
  16. dose any one know any sites that would have a free blaster repair manual so i could just print it out thank you
  17. i have stock tires and i would like to know if anyone has any suggestions on some good all around tires. by all around i mean sand dunes , mud , rocks , gravial trails , grass , what ever and were ever the shee can go, not realy for snow because i am looking at those 4 snow tires. are they any good ? so if any one knows realy good all around tires please write the company or a link to look at or any pictures any thing thank you
  18. i need sites that have clips that you can watch off the site any links that have atv video clips that are free to watch videos clips anything help
  19. my first atv i ever tried or owned was a banshee for a novice driver the shee is crazy! so much power i did not know what to do with it. i am still a novice driver but i had money to wast for some tr6 pipes jets air filter and now it is still crazy fast. i will one day harness the speed and get more mods. i know this is a banshee site and no one will put the shee down but the only atv i ever tried was the banshee i never road any other atv so i cant compared it to any other atv so is the banshee realy all that or is it just like any other atv 2 or 4 stroke i know it is not just like all the other atvs but if it is better what makes it better if you honestly could have any atv with any mods what would it be. oh by the way those f**ken 4 stroke are realy getting good or should i dare say better then the shee the 4 strokes i am talking about are the trx 450r honda and the yamaha yfz 400 or 450 that new one that kinda looks like a raptor would it realy beat the shee or at least give it ,its run for its money
  20. how much oil do you put in the transmison
  21. my banshee has toomey tr6 pipes and it is jetted with the jets that came with the pipes and i also have a pro design air filter how high do you think the rpm gose on my shee?????
  22. i run 2 stroke gearbox oil transoil (motul) beside the number of hours you ride how else would i know to chang it would it turn black and or smell realy bad or will it turn gray as long as there is oil on the dip stick dose that mean there is enouf oil in the transmision help me before i kill my banshee i only changed my oil one time how much oil do i put into a empty gear box do i put the whole can of oil half the can or what how many ml of oil i am from canada so i am not sure on the coverson of ml to onces or what ever sorry please help me any other information would be great
  23. 2003 stock banshee 2003 banshee with pro design air filter toomey tr6 pipes and jetted for the pipes how high dose the rpm go some one said 8500 some one else said 10 somthing but who knows what he has as mods what about the leading 4 stroke how high dose their rpm go
  24. 2003 stock banshee 2003 banshee with pro design air filter toomey tr6 pipes and jetted for the pipes how high dose the rpm go some one said 8500 some one else said 10 somthing but who knows what he has as mods what about the leading 4 stroke how high dose their rpm go
  25. help me do a whilie why is it hard i am a novie driver so there is only so far i can push my banshee so i was woundering if my shee will last me long since i am not crazy i take care of it like wash it wash air filter grease it any hint on how to do a whilie i need some help my friends have an artic cat dvx400 and his atv is whelie happy 4 stroke are easyer to do whileis with the 300 ex and 400ex pop up like nothing it is all that damm torke help me pop up my banshee also anyone know any sites to see a gas tank holder for the shee
