yan
Everything posted by yan
  1. how high dose the rpm go on a banshee
  2. as i read and what my friends have told me those yfz 450 and the trx 450r are kick a** atvs. better and more reliable then a banshee. i heard that banshee can not go on long ride for long distance because on over heating and because the sheee could blow a piston at any time. how high does the rpm go on a banshee how high does the rpm go on a raptor i heard that the rpm on the yfz 450 gose up to 11 something the trx 450r gose up to 10 somthing has the banshee see its day stock to stock or miner mods like air filter ,jets, pipes
  3. And be sure and stay away from pressure washers. They will screw up bushings, bearings, and seals in a hurry. some one wrote that on this site is it realy that bad because i use the pressure hose alot soap and give her hell point blank with the pressure hose and not let it run after i just leave it there in the garage to dry
  4. i have toomey tr6 pipes and i jetted my banshee with the jets that came with the pipes and i also have a pro design air filter i would like to know how long a full tank of gas would last if i would ride hard also i would like to know if anyone has any tips on carrying gas or anything around those lines. how high dose a banshee reve dose a banshee break alot and when it dose i cost alot
  5. 1" unifilters is that the little circle air hole with like a little fome thing inside? if so i have two on top ,two on each side and six on back i dont have the outerwear air filter thing i washed my atv with a preasure hose and water went throw the air holes and that fome stuff right in to the air box preasure hose can it f**k up the banshee
  6. 1" unifilters is that the little circle air hole with like a little fome thing inside? if so i have two on top ,two on each side and six on back i dont have the outerwear air filter thing i washed my atv with a preasure hose and water went throw the air holes and that fome stuff right in to the air box preasure hose can it f**k up the banshee
  7. i use 20 liters of gas with 500ml of oil is that good 10 liters gas 250ml oil 5 liters gas 125ml oil 2.5 liters gas 60ml oil how much gas fits in the banshee gas tank also does anyone fill their banshee gas tank at the gas station and then put the oil stright into the atv tank depending on how much gas you put in. so instead on carrying a big red spear tank all i would have to carry is a little oil tank. what is your oil gas ratio mixture. no lid on air box should i stay away from mud and water
  8. dose that cover go over the both pro desige air filters
  9. is that pro design filter any good. i use pro design double filter thing and i use the oil spray in the can and i clean it in gas. is that all good. sometimes i will only have to clean the red outerfilter is that ok or should i clean both
  10. i use 20 liters of gas with 500ml of oil is that good 10 liters gas 250ml oil 5 liters gas 125ml oil 2.5 liters gas 60ml oil how much gas fits in the banshee gas tank also does anyone fill their banshee gas tank at the gas station and then put the oil stright into the atv tank depending on how much gas you put in. so instead on carrying a big red spear tank all i would have to carry is a little oil tank. what is your oil gas ratio mixture. no lid on air box should i stay away from mud and water
  11. thank you
  12. banshee raptor preditor 250 r ??????????400 ex ds 650
  13. when i got my new pipes i also jetted it with the jets that came with the tr6 but the air filter looked like crap so i bough a pro design air filter. Is pro design a good air filter. So when i put it in i took off the tub that is connected to the air box that is going up so there is almost a stright path for sand mud and water to get in. should i stay away from water mud and shit like that. one of my friends took off his air box cover (lid) completly and he said he it does not matter. water mud ???????????? sand + stright path = wash air filter alot
  14. thank you coooooooooool
  15. i know it also depends on the driver but if the drivers are all equal and all the atvs are stock which atv is faster. try not to be biest because this is a banshee site but be honest. yamaha banshee vs raptor vs honda 400ex vs artic cat dvx 400 what is mxing mx? also is banshee a good all around atv like in mud ,water and sand , woods ect
  16. how do we post pictures
  17. http://www.toomey.com/html/tr6.htm look at this link they have dyno charts to compare some pipes. personaly i would chose the tr6 toomey pipes. they kick butt!!!!!!!
  18. how do we post pictures
