yellow&chrome
Everything posted by yellow&chrome
  1. Thanks for your response vmaxup. no i do not run a boost bottle and yes I do do my leak down with my boots on. Why would badass r6 say that i should only do one side then the other. Good news is that my whole motor does hold 6lbs. for 6 minutes. My carbs have been cleaned several times and main jets triple checked any other suggestions for right side rich and left side lean according to the spark plugs.
  2. Sorry, I posted this before I saw the repairs and mods section
  3. Well I can't seem to get each side to do a leak down, but the whole motor will. So what seal is leaking for the air to go from side to the other side. Yes the carbs are sinc and each side sits at 158lbs. I am readng the plugs to see that the right side is rich and the left side is lean.
  4. Is a leak down test on a banshee to be down one side at a time or the whole motor at once? If it is supposed to be the whole motor then my motor is holding 6lbs. for 6 minutes. Then why is the left side lean and the right side rich if I have no leaks. Thanks in advance for all your help!!!
  5. When doing a leak down test should you be able to do one side then the other or do you have to do the whole motor at once. Because my motor won't allow me to do the right then the left, but the whole motor will hold 6lbs. for 6 minutes. Is this OK, if not what problem do I have? Thanks in advance for any and all the help!!!
