sanddragbanshee
Everything posted by sanddragbanshee
  1. you need to put the lock-up clutch kit and get you a longer swingarm that way you can dump the clutch and just hang on.
  2. CPI INFRAME OR OUT FRAME ARE THE BEST PIPES AROUND .
  3. I WOUNDN'T GO ANY BIGGER THAN 370 OR 397 KITS BECAUSE I GOT A 370 LONG ROD AND I CAN RUN WITH 5, 7 , OR 10 MILL STROKERS I KNOW SOMEONE WITH A 7 MILL 505 T-REX BANSHEE DRAG PORT WITH 41MM ALCOHOL CARBS AND EVERY THING ELSE AND WE ARE SIDE BY SIDE. I RUN 4.20 OR 4.30 IN 300FT. DIRT DRAG AND I WEIGH 230 POUNDS.
  4. I HAVE A DRAG BANSHEE WITH A 370 LONGROD MOTOR DRAG PORTED ON ALCOHOL AND I RUN 25X11X9 12 PADDLE TALLER HAULERS OR 21X11X8 12 PADDLE EXTREMES AND I RUN 16/41 GEARING AND TURN THEM WITH NO PROBLEM.
