I finally got mine on and they look & work great!! I had to do the grinding on the top & btm shock mounts, but I also had to grind a little off the bottom of the shocks itself. It would hit the btm of the a arm before it would line up with the bolt hole! Believe me I tried everything possible to avoid having to grind on the shock but, nothing worked. After I grined a little off the shock it worked fine..only had to grind maybe 1/8 inch.
Did anyone else have this problem??
thanx,
JLew
