plug9992
Everything posted by plug9992
  1. yeah, I need a free play....cause I wheely every bump!
  2. s'cuse my typing: the kit is sold by magic racing...!
  3. Yeah, does Motion Pro sell it? Cause the kit sold by racing includes the carbs cover and I don't need them.
  4. Hi guys! I raced a RM125 for many years and since I've my shee, I wanted to get a twist throttle from motion pro. I removed all the Tors and electronic junk and I calibrated my throttle valves (for Idling) with the 2 screws on top of the carbs. But it's very sensitive, when I jump, I'm always hitting the throttle a little bit and sometimes It's not fun! I heard about idle screws, but you've to drill the carb body, tap it, and install them. With that setting, you're probably able to get a free play on the thwist throttle. Anybody has tryed that set-up? Do you have a recommandation or it's useless for me to buy the screws? Thanks!
  5. Hi! I'd just like to know if it's possible to install a banshee axle on a blaster. I dont want to loose my time trying it. Thanks! PL
  6. Hi! I'd like to know if I install a DYNA FS box on my shee, would you recommand to buy the "progammable kit " with software? The handlebar switch (to change the ignition curve) is an option too? If you guys, have a DYNA fs, could you tell me If it's possible to preset the max RPM or start rpm (for drag) with a conventionnal FS box? It's not clear on their website,please help! Thanks! PL
  7. I use 13,14 and 15 t. sproket. My preffered one is the 13, wheelying is easy, start like a spring and your friends with craptors will shut up for ever!
  8. As a machinist, I'm planning to lighten my flywheel and modify my stator plate as suggested on this forum. But I have a question, anybody got overheat problems with a +4 timing? It seems to be OK but I'd prefer to know the consequences before doing it. Next, if I remove 0.30 from my stock head, do I have to modify the squish geometry? Thanks Banshee 2001 TR6 Boyesen reeds Reed spacer Hi-flow twin intake Durablue filter NGK racing wire DID racing chain Douglas wheels Razr 2 tires
  9. Hi, I'd like to know if it's necessary to remove the TORS system if I install a twist throttle? I don't have any problem with the tors, so if it's possible, I 'll just replace the harsh thumb throttle. Finally, ifI can do it, what about the small switch on the throtthle? Any suggestion?
  10. And the NOS button...!
  11. Hi! It may look stupid, but I've seen a buddy who was riding a banshee with sand tires in the snow. It was a blast to see, but I don't know if it was effective. What do you think? Maybe it's an alternative for the ugly "4 snow"
