cjc
Everything posted by cjc
That sucks man. I would have helped you out with the gate and sign up fees,but it's still a long ass ride with only a little pocket money! hope you can make the next one, let me know if you need any help with the yfz.
WE had a lot of fire roads and logging roads were we could open them up for long periods of time , On the pipe in 4th in the tighter sections, and wfo in 6th on the open roads,that is my favorite kind of riding !! Its been way too long since I rode it, I think I'm going to dust it off and get it going again . Whats the verdic for tomorrow, did everything come together for ya, are you still comming to race ?
Thats about what I was thinking +10 and some re ported cubs, strip it down , put a +4 or +6 swinger on it . there is a lot of street drag racing in ocala ,mostly on the west side in a industrial area by the airstrip .
I'v only done a little MX practice,a few gncc races and lots of trail riding, and TT and flat track racing. When we were in the woods we went flat out ,we dont trail ride anymore the feds shut everthing down! My poor banshee gets the same treatment,since I got the YFZ. We had a huge crew comming up from naples,they all have 2nd houses out here in the national forest.
If you bring her she can play with my daughter and all the other kids that play together. I have been throwing around the idea of converting mine to drag,we have a lot of guys running for $$$ in town every couple of weeks ! and those would be what I would use (inframes) I have the propegs also ,mine are moved down and back ,I had to get a -1.5 aluminum brake lever and -1.5 shifter. Its a lot better when standing,you dont feel like your perched above the tank and bars. I would have liked to put some high dollar shocks on my banshee,with some +2 a arms! What kind of riding do you usualy do?
How old is your child? My daughter is 12 and there are a lot of kids that play together during the races . I sure like the look of them pipes ! I bet with those and ported cylinders it must pull like hell !! Do you ever burn your pants ? Your nerfs look the same as mine, are they the lowered 1.5" and back 2" model ?, It sure changes the ergo's for the better!! Those are the same A arms I first got for jons blaster,very durable ! How do you like those elka's,those must have made one hell of a difference.
There all right ,nothing special . I would like to see that rz powered banshee of yours Ive never seen one up close yet. are you still trying to make it on the 8th. Im going over the 450 now , check valves, filter , shock pressures ,chain, ,just trying to get ahead of to curve for once!
I have an 06 yfz , lrd hmf hybrid pipe, jetted ,dyna cdi , pro flow uni , cam mod , heaver clutch springs , + 2.5 lt A arms, fox dsc shocks, swaybar with aluminum tube , -2 swinger , + 4" axle , 05 rear shock with 06 spring , armd rear lowering link , nerfs , handguards , hot start , to much other crap to remember! I also have a banshee but its not set up yet ,it has the normal mild stuff , ptr pipes , 18 cc head , v force ,pro flow uni , Ims oversize radiator, it was set up for gncc racing. We also have a blaster its my sons (was) he pilots my 450 now ! I will detune it for my daughter in the next couple of seasons , the blaster is pretty sick , 240 la sleeve 12 port cylinder-head,armd tt ported ,38mm, 250r V force reeds-intake, right side exit high rev pipe , +4 key, hd clutch-springs ,banshee axle ,armd +3 a arms for yfz spindles, swaybay,armd front lowering bracket for yfz shocks ,armd rear lowering link my daughters custom raptor,badger 80, + 10" wide front and rear, + 1.5 wheel base , 4" lower , fox float rear shock, blaster nerfs, 4 speed conversion ,custom raptor 110 cc bigbore stroker , 15-8-1 cr engine, +4 mm valves , 125 ttr cam, 24 mm flat slide ,dyna cdi, 1"id hand formed stainless headpipe- white bro race can, sitting on hoosiers ,nothing stock except steering stem ,front hubs! My best friend's banshee we are still seting up, it is a armd 374 196-130 , t-5s , large 2 into 1 intake (no trinity cv) 39mm , reeds, +3 a arms ,stock shock bodies with duel rate springs , swaybar, +4 axle ,armd -3 swing arm stock rear shock with cr 500 spring ,lowering link , nerfs
It's no problem with the tires,like I said you can use a spare set of mine if you want to run something other than the knobbie class !
I wouldnt worry about your bike there are lots of mild quads to run with. what kind of racing, riding experience do you have ? what kind of safty gear,they require, helmet,chest protector,pants, long sleeves,goggles,gloves,and boots that completely cover your ankle bone . killswitch is required, but will let slide , nerfs are not required,but are needed! I would like to see your banshee run on our flat track it sounds stacked. there are a few banshees that run with us 4-5 but they never seem to all show up at the same race ! what kind of 450 do you have, is it a yfz If so I also have a set of spare rear rims and tires you can use for the nite 59-8-10 on 4+5 wheels if the offset is greater than your hipers . if you dont want the tires i told you about earlier let me know either way I have someone that wants the fronts and maybe the rears also
Most of the faster quads are 450's for TT. we campaign with a stock yfz with nothing more than a pipe ,uni filter with pro flow flange , jetting ,cam mod . the chassis is has a lot of mods, Aarms, shocks, swingarm, swaybar. Nobody believes it's stock because we do pretty well . Its more about setup and riding skill, than HP. flat track is a different story ,if the track comes in realy good, the modded bikes are harder to pass if they can hook up. how is your 450 set up ,is it wider,or lower, both? A MX setup works ok for TT just set it up softer and a little lower I wouldnt worry about the bike much, they will have a class you will have lots of fun in. I have some brand new rear tires 59-10-9 rd 12 that will fit stock rims and some used front tires 57-6-10 rd 12 if you want to run something other that knobbie class . if your interested pm me i will give you a price I can mount them at the track!
pm me whenever your thinking about going, I will look for you . we had 3-4 new guys show up last night from somewhere around crystal river, A banshee and a few 450s Our next race on 8-8-09 is a TT only, the next flat track race is on 8-22-09 I hope to see you out there !
Yes they have two rounds of practice before the heats start, and hold an all day practice on sunday's I hope to see you out there its a blast !
Thunderbowl Speedway' s King Of The Dirt TT and flattrack racing 2009 summer/fall points series Come join the fun and grow with us we have classes for everyone ! peewee A-B , youth , novice , sportsman , ladies , knobbie , vet 30+ and 40+ , 2stroke , intermediate , open pro money , pro am money , rinos and razors and other utvs , along with utility quads. There is a lot of exciting racing action for everybody to watch, or to take part in! we have a large turn out of motorcycles with lot's of classes, we also run mini and, micro sprints, and gadgets. the prices are great $10 gate fee for ages 5 and up, the race fees are only $5 for peewees, $30 for all other classes except, $ PRO money $ it's $50 for more info on classes , rules , links and photos go to thunderbowl speedway home page or visit atvflorida go to the thunderbowl page for weather issues or other immediate concerns for Email reply Brady W. for phone reply Brady W. 352-266-3466 or Rick D. 352-266-1961 check out some TT racing action her is the flat track racing for more race video just look for my other video's on my youtube site JULY 25th- TT & Flat Track AUGUST 8th- TT 22nd- TT & Flat Track SEPTEMBER 5th- TT 12th- TT 26th- Flat Track OCTOBER 10th- TT 17th- Flat Track 24th- TT NOVEMBER 7th- TT & Flat Track 21st- TT & Flat Track DECEMBER 5th- Flat Track 12th- TT For race days with one event, gates open at 3pm and practice to start at 4:30pm For race days with two events, gates open at 9am and practice to start at 10:30am
Hello All. I was just wondering if anyone was planning on racing this weekend? there is a flat track race in MILTON FL at southern raceway on FRI ,and a TT race then a flattrack race SAT in LOXLEY AL at deep south raceway! I think the race Fri is sanctioned ,but I believe the races on sat are outlaw and a few are money classes ! for all the details contact Rob Mclendon @ 850 637 5838
www.SouthernDirtTrackAssociation.Com $$ Next race on 6-21-08 $$ We would like to invite everyone to our next race on the 21st ! The track is a 1/4 mile ,red clay surface with great traction! Jasper is a nice facility, very friendly staff, great racing !! RACE SCHEDULE ________________________________________ 1. Crossroads Motorplex Jasper Fl. 1/4 mile Saturday Feb 29, 7pm. -no points, just money. 2. Auburndale Speedway Auburndale Fl. 1/5 mile Saturday April 19, 12 noon. -points. 3. Ocala Speedway Ocala, Fl. 3/8 mile Saturday May 17, 2008. Gates open 10am, practice 12pm, racing 2pm. -points will accrue, money classes TBD. 4. Sumter County Fairgrounds Webster Fl. 1/4 mile oval www.sumterracing.com May 24, 2008 Sat time 12pm $500 Quad and $500 Motorcycle Class in addition to all regular classes! 5. Crossroads Motorplex Jasper Fl. June 21, 2008 , money classes TBD gates open at 4pm pratice at 5pm racing at 7pm 6. Auburndale Speedway Sat Aug 2, 2008. -racing at 6pm. -points will accrue, money classes TBD. . check for current info go to atvflorida.com go to racing scene look in southern dirt track association page at the top CLASSES Here is a list of classes for the 2008 SDTA summer series. * Open Pro Quad: Any bike, any frame, any motor - Fast Guys Only! * Pro Production Quad: Factory produced 4 stroke bikes ONLY. NOT to exceed 450cc. No 2 strokes, aftermarket frames, hybrids, big bores, strokers, etc. (this class will be run on a selective basis) * Intermediate "B" Quad * Novice "C" Quad * Sportsman: 16 and up adult class. 4 strokes not to exceed 400cc, 2 strokes not to exceed 250cc. 250R's & LT250R's must be COMPLETELY STOCK. * Veteran 30+ Quad * Senior 40+ Quad * Ladies "A" Quad- For the faster ladies * Ladies "B" Quad - For the newer ladies * Youth Quad: 11- 15 years old. 4 strokes not to exceed 400cc, 2 strokes not to exceed 200cc. NO BIG BORE KITS, MOTORS, ETC. * Pee Wee Quad "A": 80cc - 150cc * Pee Wee Quad "B": Less than 80cc * Micro Sprint * Knobby Tire Classes- There will be knobby tire classes on the tracks that allow it. Please look at each individual races information regarding knobby classes. * Expert Motorcycle-Must have previous racing experience in that class unless promoted by SDTA, any bike, any age, over 14yrs old. * Amateur Motorcycle-Minimum or no racing experience, any bike, any age over 14 * Vintage Motorcycle-Bike must be pre 1990 model, any bike, any age * Super Senior Motorcycle-Rider must be at least 50 yrs old. ( youth / pee wee motorcycle classes can be provided if the need arises) As always, any of these classes are subject to being eliminated and/or combined www.SouthernDirtTrackAssociation.Com TRACK DIRECTIONS Crossroads Motorplex Jasper, FL 1/4 mile oval http://www.crossroadsmotorplex.com Link to pictures of track http://www.ranlayracing.com/999crossroadsdirt.HTML WADE MURPHY TRACK 386-938-1228 HOME 386-938-3481 DIRECTIONS TO TRACK: EXIT 460 OFF I 75 GO WEST ON STATE RD 6 FOR 4 1/2 MILES. THE TRACK IS ON THE LEFT GATES OPEN AT 4 PM PRACTICE AT 5 PM RACING AT 7 PM CAMPERS ARE ALLOWED TO STAY OVERNIGHT BUT NO HOOKUPS Days Inn Jasper (386) 792-1987 8182 State Road 6 W www.daysinn.com - ------------------------------------------------------------------------------- Eastbay Raceway Park Riverview, Fl. 1/3 mile oval 6311 Burts Road, Tampa Florida 33619 813-677-7223 www.eastbayracewaypark.com From I-75 take exit 260, Gibsonton Dr. Go West on Gibsonton Dr Go North on US 41 Go East on Burts Rd then watch for signs. -------------------------------------------------------------------------------- Auburndale Speedway 1/5 mile oval Quad, Trike, and Motorcycle Flat Track Racing 5640 State Road 542 W Winter Haven, FL 33880 (863) 551-1131 For the April 19th event: gates open at 9am practice at 10am open registration 9:30-11:30am drivers meeting 11:35am races start at 12 noon www.auburndaleracing.com Directions to track from I-4: From I-4 take Exit 27 Polk Parkway toll road toward Lakeland/Winter Haven. Exit on Hwy 92 (Memorial Hwy), go East Turn right on Recker Rd Turn right on 542 Track is 1/2 mile on left ------------------------------------------------------------------------------ Ocala Speedway 3/8 mile clay oval 9050 NW Gainesville Rd. Ocala, FL 34482 352-622-9400 http://www.ocalaspeedway.com/ Race date is Saturday, May 17th Gates Open at 10 am Practice at 12 pm Racing starts at 2 pm From points south of Ocala via I-75 Take the SR-326 exit, exit number 358. Keep RIGHT at the fork in the ramp. Turn RIGHT onto FL-326. (0.7 miles) Turn LEFT onto CR-25A. (NW Gainesville Road) (0.9 miles) Track is located on the LEFT. From points north of Ocala via I-75 Take the SR-326 exit. #358 Turn LEFT onto FL-326. (0.7 miles) Turn LEFT onto CR-25A. (NW Gainesville Road) (0.9 miles) Track is located on the LEFT. From points south of Ocala via 441/301 Turn LEFT onto SR-326. (1.7 miles) Turn RIGHT onto CR-25A. (NW Gainesville Road) (0.9 miles) Track is located on the LEFT. From points north of Ocala via 441/301 Turn RIGHT onto SR-326. (1.7 miles) Turn RIGHT onto CR-25A. (NW Gainesville Road) (0.9 miles) Track is located on the LEFT. -------------------------------------------------------------------------------- Sumter County Fairgrounds 7620 SR 471 Webster, Fl. 33597 From I-75 Exit at Brooksville onto Hwy 50 East. Cross over Hwy 301, continue east. Turn North on 471 in Tarrytown. Travel north through Webster then look for race track on west side of road behind large Ag building. If you reach the intersection of Beville's Corner then you travelled 1/4 mile too far. -------------------------------------------------------------------------------- www.SouthernDirtTrackAssociation.Com
Hello all I just wanted to invite everyone to check out our series. We have a good size group of realy nice people, lots of classes , and different tracks. If you live in the southeast and are looking for some flattrack , TT, supermoto racing ,You have found what your looking for! l for more info go to atvflorida.com go in forums to the racing scene, click on the Southern Dirt Track Association page at the top www.SouthernDirtTrackAssociation.Com Race schedule ________________________________________ 1. Crossroads Motorplex Jasper Fl. 1/4 mile Saturday Feb 29, 7pm. -no points, just money. 2. Auburndale Speedway Auburndale Fl. 1/5 mile Saturday April 19, 12 noon. -points. 3. Ocala Speedway Ocala, Fl. 3/8 mile Saturday May 17, 2008. Gates open 10am, practice 12pm, racing 2pm. -points will accrue, money classes TBD. 4. Sumter County Fairgrounds Webster Fl. 1/4 mile oval www.sumterracing.com May 24, 2008 Sat time 12pm $500 Quad and $500 Motorcycle Class in addition to all regular classes! 5. Crossroads Motorplex Jasper Fl. June ?, 2008 6. Auburndale Speedway Sat Aug 2, 2008. -racing at 6pm. -points will accrue, money classes TBD ------------------------------------------------------------------------------------------------------------------------------------- To check for current info go to atvflorida.com go to racing scene look in the southern dirt track association page at the top ------------------------------------------------------------------------------------------------------------------------------------ - CLASSES Here is a list of classes for the 2008 SDTA summer series. * Open Pro Quad: Any bike, any frame, any motor - Fast Guys Only! * Pro Production Quad: Factory produced 4 stroke bikes ONLY. NOT to exceed 450cc. No 2 strokes, aftermarket frames, hybrids, big bores, strokers, etc. (this class will be run on a selective basis) * Intermediate "B" Quad * Novice "C" Quad * Sportsman: 16 and up adult class. 4 strokes not to exceed 400cc, 2 strokes not to exceed 250cc. 250R's & LT250R's must be COMPLETELY STOCK. * Veteran 30+ Quad * Senior 40+ Quad * Ladies "A" Quad- For the faster ladies * Ladies "B" Quad - For the newer ladies * Youth Quad: 11- 15 years old. 4 strokes not to exceed 400cc, 2 strokes not to exceed 200cc. NO BIG BORE KITS, MOTORS, ETC. * Pee Wee Quad "A": 80cc - 150cc * Pee Wee Quad "B": Less than 80cc * Micro Sprint * Knobby Tire Classes- There will be knobby tire classes on the tracks that allow it. Please look at each individual races information regarding knobby classes. * Expert Motorcycle-Must have previous racing experinece in that class unless promoted by SDTA, any bike, any age, over 14yrs old. * Amateur Motorcycle-Minimum or no racing experience, any bike, any age over 14 * Vintage Motorcycle-Bike must be pre 1990 model, any bike, any age * Super Senior Motorcycle-Rider must be at least 50 yrs old. ( youth / pee wee motorcycle classes can be provided if the need arises) As always, any of these classes are subject to being eliminated and/or combined www.SouthernDirtTrackAssociation.Com TRACK DIRECTIONS Crossroads Motorplex Jasper, FL 1/4 mile oval http://www.crossroadsmotorplex.com Link to pictures of track http://www.ranlayracing.com/999crossroadsdirt.htm WADE MURPHY TRACK 386-938-1228 HOME 386-938-3481 DIRECTIONS TO TRACK: EXIT 460 OFF I 75 GO WEST ON STATE RD 6 FOR 4 1/2 MILES. THE TRACK IS ON THE LEFT GATES OPEN AT 4 PM PRACTICE AT 5 PM RACING AT 7 PM CAMPERS ARE ALLOWED TO STAY OVERNIGHT BUT NO HOOKUPS Days Inn Jasper (386) 792-1987 8182 State Road 6 W www.daysinn.com - ------------------------------------------------------------------------------- Eastbay Raceway Park Riverview, Fl. 1/3 mile oval 6311 Burts Road, Tampa Florida 33619 813-677-7223 www.eastbayracewaypark.com From I-75 take exit 260, Gibsonton Dr. Go West on Gibsonton Dr Go North on US 41 Go East on Burts Rd then watch for signs. -------------------------------------------------------------------------------- Auburndale Speedway 1/5 mile oval Quad, Trike, and Motorcycle Flat Track Racing 5640 State Road 542 W Winter Haven, FL 33880 (863) 551-1131 For the April 19th event: gates open at 9am practice at 10am open registration 9:30-11:30am drivers meeting 11:35am races start at 12 noon www.auburndaleracing.com Directions to track from I-4: From I-4 take Exit 27 Polk Parkway toll road toward Lakeland/Winter Haven. Exit on Hwy 92 (Memorial Hwy), go East Turn right on Recker Rd Turn right on 542 Track is 1/2 mile on left ------------------------------------------------------------------------------ Ocala Speedway 3/8 mile clay oval 9050 NW Gainesville Rd. Ocala, FL 34482 352-622-9400 http://www.ocalaspeedway.com/ Race date is Saturday, May 17th Gates Open at 10 am Practice at 12 pm Racing starts at 2 pm From points south of Ocala via I-75 Take the SR-326 exit, exit number 358. Keep RIGHT at the fork in the ramp. Turn RIGHT onto FL-326. (0.7 miles) Turn LEFT onto CR-25A. (NW Gainesville Road) (0.9 miles) Track is located on the LEFT. From points north of Ocala via I-75 Take the SR-326 exit. #358 Turn LEFT onto FL-326. (0.7 miles) Turn LEFT onto CR-25A. (NW Gainesville Road) (0.9 miles) Track is located on the LEFT. From points south of Ocala via 441/301 Turn LEFT onto SR-326. (1.7 miles) Turn RIGHT onto CR-25A. (NW Gainesville Road) (0.9 miles) Track is located on the LEFT. From points north of Ocala via 441/301 Turn RIGHT onto SR-326. (1.7 miles) Turn RIGHT onto CR-25A. (NW Gainesville Road) (0.9 miles) Track is located on the LEFT. -------------------------------------------------------------------------------- Sumter County Fairgrounds 7620 SR 471 Webster, Fl. 33597 From I-75 Exit at Brooksville onto Hwy 50 East. Cross over Hwy 301, continue east. Turn North on 471 in Tarrytown. Travel north through Webster then look for race track on west side of road behind large Ag building. If you reach the intersection of Beville's Corner then you travelled 1/4 mile too far. -------------------------------------------------------------------------------- www.SouthernDirtTrackAssociation
Hello all I just wanted to invite everyone to check out our series. We have a good size group of realy nice people, lots of classes , and different tracks. If you live in the southeast and are looking for some flattrack , TT, supermoto racing ,You have found what your looking for! for more info go to atvflorida.com go in forums to the racing scene, click on the Southern Dirt Track Association page at the top www.SouthernDirtTrackAssociation.Com Race schedule ________________________________________ 1. Crossroads Motorplex Jasper Fl. 1/4 mile Saturday Feb 29, 7pm. -no points, just money. 2. Auburndale Speedway Auburndale Fl. 1/5 mile Saturday April 19, 12 noon. -points. 3. Ocala Speedway Ocala, Fl. 3/8 mile Saturday May 17, 2008. Gates open 10am, practice 12pm, racing 2pm. -points will accrue, money classes TBD. 4. Sumter County Fairgrounds Webster Fl. 1/4 mile oval www.sumterracing.com May 24, 2008 Sat time 12pm $500 Quad and $500 Motorcycle Class in addition to all regular classes! 5. Crossroads Motorplex Jasper Fl. June ?, 2008 6. Auburndale Speedway Sat Aug 2, 2008. -racing at 6pm. -points will accrue, money classes TBD ------------------------------------------------------------------------------------------------------------------------------------- To check for current info go to atvflorida.com go to racing scene look in the southern dirt track association page at the top ------------------------------------------------------------------------------------------------------------------------------------ - CLASSES Here is a list of classes for the 2008 SDTA summer series. * Open Pro Quad: Any bike, any frame, any motor - Fast Guys Only! * Pro Production Quad: Factory produced 4 stroke bikes ONLY. NOT to exceed 450cc. No 2 strokes, aftermarket frames, hybrids, big bores, strokers, etc. (this class will be run on a selective basis) * Intermediate "B" Quad * Novice "C" Quad * Sportsman: 16 and up adult class. 4 strokes not to exceed 400cc, 2 strokes not to exceed 250cc. 250R's & LT250R's must be COMPLETELY STOCK. * Veteran 30+ Quad * Senior 40+ Quad * Ladies "A" Quad- For the faster ladies * Ladies "B" Quad - For the newer ladies * Youth Quad: 11- 15 years old. 4 strokes not to exceed 400cc, 2 strokes not to exceed 200cc. NO BIG BORE KITS, MOTORS, ETC. * Pee Wee Quad "A": 80cc - 150cc * Pee Wee Quad "B": Less than 80cc * Micro Sprint * Knobby Tire Classes- There will be knobby tire classes on the tracks that allow it. Please look at each individual races information regarding knobby classes. * Expert Motorcycle-Must have previous racing experinece in that class unless promoted by SDTA, any bike, any age, over 14yrs old. * Amateur Motorcycle-Minimum or no racing experience, any bike, any age over 14 * Vintage Motorcycle-Bike must be pre 1990 model, any bike, any age * Super Senior Motorcycle-Rider must be at least 50 yrs old. ( youth / pee wee motorcycle classes can be provided if the need arises) As always, any of these classes are subject to being eliminated and/or combined www.SouthernDirtTrackAssociation.Com TRACK DIRECTIONS Crossroads Motorplex Jasper, FL 1/4 mile oval http://www.crossroadsmotorplex.com Link to pictures of track http://www.ranlayracing.com/999crossroadsdirt.htm WADE MURPHY TRACK 386-938-1228 HOME 386-938-3481 DIRECTIONS TO TRACK: EXIT 460 OFF I 75 GO WEST ON STATE RD 6 FOR 4 1/2 MILES. THE TRACK IS ON THE LEFT GATES OPEN AT 4 PM PRACTICE AT 5 PM RACING AT 7 PM CAMPERS ARE ALLOWED TO STAY OVERNIGHT BUT NO HOOKUPS Days Inn Jasper (386) 792-1987 8182 State Road 6 W www.daysinn.com - ------------------------------------------------------------------------------- Eastbay Raceway Park Riverview, Fl. 1/3 mile oval 6311 Burts Road, Tampa Florida 33619 813-677-7223 www.eastbayracewaypark.com From I-75 take exit 260, Gibsonton Dr. Go West on Gibsonton Dr Go North on US 41 Go East on Burts Rd then watch for signs. -------------------------------------------------------------------------------- Auburndale Speedway 1/5 mile oval Quad, Trike, and Motorcycle Flat Track Racing 5640 State Road 542 W Winter Haven, FL 33880 (863) 551-1131 For the April 19th event: gates open at 9am practice at 10am open registration 9:30-11:30am drivers meeting 11:35am races start at 12 noon www.auburndaleracing.com Directions to track from I-4: From I-4 take Exit 27 Polk Parkway toll road toward Lakeland/Winter Haven. Exit on Hwy 92 (Memorial Hwy), go East Turn right on Recker Rd Turn right on 542 Track is 1/2 mile on left ------------------------------------------------------------------------------ Ocala Speedway 3/8 mile clay oval 9050 NW Gainesville Rd. Ocala, FL 34482 352-622-9400 http://www.ocalaspeedway.com/ Race date is Saturday, May 17th Gates Open at 10 am Practice at 12 pm Racing starts at 2 pm From points south of Ocala via I-75 Take the SR-326 exit, exit number 358. Keep RIGHT at the fork in the ramp. Turn RIGHT onto FL-326. (0.7 miles) Turn LEFT onto CR-25A. (NW Gainesville Road) (0.9 miles) Track is located on the LEFT. From points north of Ocala via I-75 Take the SR-326 exit. #358 Turn LEFT onto FL-326. (0.7 miles) Turn LEFT onto CR-25A. (NW Gainesville Road) (0.9 miles) Track is located on the LEFT. From points south of Ocala via 441/301 Turn LEFT onto SR-326. (1.7 miles) Turn RIGHT onto CR-25A. (NW Gainesville Road) (0.9 miles) Track is located on the LEFT. From points north of Ocala via 441/301 Turn RIGHT onto SR-326. (1.7 miles) Turn RIGHT onto CR-25A. (NW Gainesville Road) (0.9 miles) Track is located on the LEFT. -------------------------------------------------------------------------------- Sumter County Fairgrounds 7620 SR 471 Webster, Fl. 33597 From I-75 Exit at Brooksville onto Hwy 50 East. Cross over Hwy 301, continue east. Turn North on 471 in Tarrytown. Travel north through Webster then look for race track on west side of road behind large Ag building. If you reach the intersection of Beville's Corner then you travelled 1/4 mile too far. -------------------------------------------------------------------------------- www.SouthernDirtTrackAssociation
