SHEEDAISY
Everything posted by SHEEDAISY
  1. hmm i beat one with toomeys , 80 over with wisecos, stock head , stock reeds , bored carbs , degree key, ricky stator , and the same gearing as you . with the gearing im in 5th and hes in 5th hiting the rev limiter, i still hada gear to go and was pulling , he kept up threw 4th buti had him the whole way .ithadthe same mods the oneyou raced did . josh
  2. i have a 6 y/o brother who rides a champ 80 . i think he is a very good rider . he knows every thing about it , and is probley going to start racing . he have been riding since he was 5 .heres some pics he never gets on itwith out his helment , and there is always some one out there with him when he is riding . the 80 is big enuff for now but he will step up to a blaster when hes 9 or 10 . josh
  3. hmm i took a piped, jeted and filtered 450 wit my shee. the 450 was geard down tooth on the front and 18in tires . my bike has .080 over bore with wisecos , bored carbs, toomey t-5s, degree key, ricky stator, and k&n clamp ons , stock reeds, stock head, and no porting . i have a 2 tooth bigger front sprocket and 22s out back . i beat the 450 . i thought you needed porting and all the other stuff ? i even out weigh theguy by over 100 lb. maybe mine is a freak shee josh
  4. its not really a bog really , it just dosnt want to seem to go into power band . i tried turning the air screws in a hafe a turn and it seemed like it helped . the plugs are a brownish color . im no expert in ready plugs or jeting . i think i will try adjusting the needle to see if that helps . i would have already bought bigger mains but none of the shops around me have big enuff jets for my needs . josh
  5. what was the nce little old lady screaming at ? josh
  6. ok sence i got my shee going , it starts up easy (1st or 2nd kick) and runs very strong but when it warms up it like it starts missng in upper rpms and dosnt want to hit the power band hard .this thing will sit and idle all day long and low speeds are not a problem . what yall think ? i think its jeting . oh and it has toomey pips and sil. , 80 over with wisecos , bored carbs , k&n clamp ons , timing advance , ricky stator , and boost bootle . it has 300 mains now . josh
  7. tps(throtal position sensor)is on top of the throtal body there the butterfly thing is . to check it turn the keyin the on position but engine off . with a digital volt meter check the green wire with the positive and black wire in the negitive one . it should be around .997-.999 . the iac (idle air control) is on the side on the egr plate behind the throtal body .take it off and clean it really well with carb cleaner and then shoot some wd-40 in there to keep it from sticking . it sounds like the tps is to high josh
  8. what do you want for the rear tires and wheels ? i am very interested . thanks josh
  9. no one knows mine ?here it is again . "you got 20 minutes to run 20 miles " or " the twin city run " josh
  10. how about this one . "you got 20min to run 20 miles " josh
  11. what size are the rear tires ? and how much . how much for the front break set up? josh
  12. it needs to be a non hard top to, so his head can stick out the top .haha i could us riding to coalfest in a sami with the shee's an a trailer . josh
  13. late 70s yamaha 80 induro bike yamaha 86 4 tech 100 yamaha blaster banshee banshee thats mine line of dirt machines i have owned . josh
  14. whats done to your stang? i have a 86 gt. josh
  15. the tires are pro wedge 2s and are 22x11x8 in size . i would like to trade a set of used 20in tires with wheels . the crank i would like to get 125 plus shiping . i am reasonable though . it needs pressed back together , but has new rod bearing on that side . josh
  16. anyone know anything ?
  17. ok as some of you know i just bought another shee . it needs a top end but when i got to looking it has a wiseco crank , rods , and pistonsin it . the guy i bought it from said it had a trinity 420 kit on it .now i dont know what kind of pistons to buy. i have no idea what it is i have asked several people and even called trinity racing and they dont know either . the number on the crank is H.R 204 , the rods have H.R 121 , the pistons have c0015 on top of them .what is it ? stock , big bore , stroker , or what . thanks in advance josh
  18. computer to slow to watch it but i think i have seen it before if its what i am thinking of .the kart that has a 3 or 4 cylinder motor on it ?does power slide like amost all the way down the straites . josh
  19. 85 champ 80 banshee yamaha 450 worrior blaster josh
  20. 125 +shiping .
  21. the real king of racing is richerd petty , but now adays i just go for whoever is driving ford or dodge . chevy can just . josh
  22. you might get him , he would be coming back at the end of the track but you would smoke him in the 8th mile .i watched a stock shee with fmf fattys as the only mod , ran 9.6 and like 68 mph in the 8th.a bone stock acorrd v6 is worth about 16s in the 1/4 mile .there pretty slow . only thing i would worry about is running out of gear .have fun josh
