ninjamaster
Everything posted by ninjamaster
  1. The paint on the a-arms wore off from riding in talll grass. How much would it cost to repaint/repowder coat the A-arms? Thanks
  2. Arent the T6s more of a mid pipe? I really like there ease of instilation looks and price. I heard that the T5s were top end. Would the T6s be good for me?
  3. Does top end mean you go in a high gear like 5th or 6th? Or does it mean that you rev it high in all the gears? Did anybody put T5s or T6s on a stock quad? If so did you lose any botom end? I dont care If I dont really improve bottom end I just dont wana lose any. Thanks
  4. repost it I gotta see what you guys are talking about
  5. Why the heck would you put another motor in a shee? Even a cr500 I would rather mod my shee. You could get the same amount of power out of a highly moded shee. It will proally cost less and be less stressful. Why put a discontinued bike motor in that is not tuned for this weight and rear wheel torque? explane
  6. Its weird. I had a yamaha big wheel 350 which is like a honda fat cat. A yamaha warior smoked me. I smoked a blaster. How are dirt bikes so fast? They dont really have the traction. I remember if I hit my big wheel all the way I would spin out and shake side to side. I seen some one do this on a Cr125. How can they get the power to the ground?
  7. Its weird. I used to have an 87 yamaha big wheel 350 and I was smoked by a yamaha warior. I did smoke a blaster though.
  8. I have some questions about my frame. Please Pm me asap. It is not about bending but about repainting/ re powdercoating. Thanks
  9. What should I check for safety every time I ride? Also what kind of prevenitive matience should I do? What kind of grease do you use in a grease gun to lube the a arms and rear swig arm (threw the grease fitting that you put the gun on)
  10. I got smoked by a stock Cr125 and even more smoked by an older Cr125 with a pipe. I want to be able to beat a Cr250 and modified 125. What mods should I do? This is still going to be my trail quad. I just like to play race on the trails. I am not even close to a drag racer. Would a tomey T5 or T6 give me the extra power to beat him? I want to do minor mods that dont take away from reliability and I dont want more matience. Thanks
  11. The 125 smoked me.
  12. The reason I weigh 285 is b/c I am a power lifter.
  13. I have an 01 banshee stock suspension. I weigh 285 pounds. What is done wrong when riding that cuses a shee to flip/ roll?
  14. What is the differance between the Toomey T5 and T6? Are the sclincers the same size? Which have larger pipes and look better? Do they sound the same? I heard that the T6 is a low to mid range and the T5 is a top end pipe. I dont want a 2 to 1 because I like dual exhaust
  15. 2 into one? Do you lose the dual exhaust and only have 1 pipe?
  16. Do I need to do anything? Did I screw up my jetting? Could I just run 32:1 and mix it in with the 24:1? Thanks for your help
  17. what is the best plugs for a banshee? I was thinking NGK 2411 B8ES?
  18. Hey, I posted about my shee back fireing and smokeing. Someone said that my jetting is off. How could it have gotten off? It is ohmost a new quad. It ran fine. I just put 24:1 instead of 32:1. Maybe thats the problem?
  19. Where can I read up? Where is all the info????
  20. Hey, I have a 2001 yamaha banshee with a boost bottle. I like to rev the heck out of my banshee . I dont really go higher then 3rd gear. Mostly because I weigh alot and dont want to hit pot holes going fast. Instead of going in low rpm 3rd I would rather run it high rpm 2nd. My buddy put older style trinity pipes on his banshee. He lost his bottom end and had to put reds and stuff. I dont want to lose any bottom end. I dont really think I will mod my banshee any more then the boost bottle and pipes and sclincers. I will get the crome. I do want the best sounding pipes. I think the t5s sound good. What is the best sounding ones out there? Will I lose any power at all i.e. Throtle responce? When you gain top end does that mean that it takes off when you rev it higher. Are these pipes a direct replacement or do I have to cut plastic? Thanks for your help I really apreciate it!
  21. sweet site.... I am looking for the best sounding pipes
  22. The plugs have black oil around the top ring, they are black near the grove where it sparks. What does a bad plug look like? I was thinking of mixing some 32:1 to fill the tank up half way and scraping the plugs with a wire brush. Then starting it and running it all out and getting it ready for winter. I had fun yesterday i t was not to cold.
