jsyi
About jsyi
  • Birthday 05/28/1984
Contact Methods
  • AIM
    onewaymtrsprts
  • MSN
  • Website URL
    http://www.angelfire.com/hi5/phu_ket_racing/predator.html
  • ICQ
  • Yahoo
    oneway_motorsports
    El Centro, CA/Tempe, AZ
  • Interests
    Quads, chicks, trucks
jsyi's Achievements
  1. jsyi
    Banshee Roller....
    I need a roller....just need a project to work on....Thanks..
  2. Let me know what you have and how much. Thanks.
  3. Looking for a set of wheels w/ reinforcement rings....for the front... Thanks.
  4. Anyone got any in good condition that they wanna unload? Thansk.
  5. Anyone have any they'd want to unload? looking for some w/ reinforcement rings.... such as the the T-9 Baja's. Thanks.
  6. Sounds like you're in a bind j/k
  7. Oh ya I forgot to add....from what i've heard ASR uses' some real crappy heims on their upper arms......If you get arms I'd go with quicksand....i've heard good stuff bouts them....plus I got a real anal friend taht just ordered a set....he wouldnt order em if he didnt thkn they were worthy.....oh ya but also cuz they were more in his price range.... dont cry matt if you read this:)
  8. Heim joints CAN BE stronger assuming you arnt using a dinky wink little heim. The term "heim" came from the company H.G. Heim that was granted the patents for the design. Heim joints date back to WWII. Germans used these rod ends on their planes. Heims started out being used on airplanes but soon became used in the power transmission industry. There are currently over 15 US companies that produce these types of rod ends. They range from stamped steel ends to stainless steel ones. The 17-4 PH stainless rod ends are prob the strongest of rod ends. If your links are going to see a lot of side load you'll want to avoid using a heim as this will wear them out quickly. Heims are less likely to bind up compared to ball joints which are limited to the amount they can move.. The whole thing about using heims and mounting them is very important. A heim mounted in double shear means that the heim joint has mounting material on both sides of it with a bolt passing through it all. The shear stress that passes through the heim joint then is passed onto the bolt. If the bolt is mounted in a double shear mount, then the stress goes through more than one point of the bolt. There is more than one plane for the force to go through. A single shear mount only has one plane for the force to be transfered through adn thus is weaker than a double shear mount of the same size. The double shear is stronger than a single shear BUT if you use a large enough bolt ia single shear mount shouldnt be a problem. With very little wear on a heim it is possible for it to pop out. where as the ball joint would have to wear a humongous hole for it to pop out...but would most likely break with a little play....uh...i think thats all for now....oh ya btw heims DO need to be maintained and checked more so than ball joints.....ball joints having a boot keeps them out of contact with the sand, dirt, blah blah blah that heims are more likely to see. I guess you could relate these two to an O-Ring chain vs. a Non O-Ring chain.... the non o-ring CAN last as long as an o-ring chain if maintained and lubed properly.....
  9. Have any of you guys here gotten TCS shocks from TCS directly? A buddy ordered a set and just received them. They were dinged up to hell and had lots of imperfections in the finish such as paint blemishes on the coils and chips...looked as if they had just been run over by a log skidder(and by no means am I exaggerating. Considering you are paying $700+ you would think it would arrive in perfect condtion....the packaging it arrived in was great....so I am assuming that the coils and shocks were already dinged and chipped prior to being shipped. I dont want you guys to think im ranting about nothing... My next question is.......what kind of shock body does TCS use. The body of the shock resembles my friends Fox to the "t". Any input would make me jump for joy. Thank ya'll for taking your time to read this extremely lengthy post. Here's a few pics of what these trampled shocks look like.
  10. where exactly in nor cal are you? would you meet part way for a little extra? Thanks. Im in so cal...bout 30 minutes from glamis..
  11. jsyi
    Ext. A-Arms
    Im looking for a set of extended a-arms in good condition. not concerned too much on brand as long as they are in good shape and the price is right:) Let me know what you have. Thanks.
  12. lookin to get a set of dual rate piggy backs w/ comp. only adjustment
  13. I was just looking around for some elkas and I noticed that it seems they are all fixed prices......or is there somewhere that sells them for less? Thanks.
  14. http://www.bjsatvrentals.com http://www.AcademyRentals.com http://www.stevesatv.com/index.html http://motorsportrentals.com/cgi-bin/start...port/index.html http://www.sandandseatoyz.com/ The closest one to glamis would be Get'n Dirty but they do not have a website that I know of. They are actually in Brawley. From what I have heard from others this is the best place to rent from and their prices are probably the best of the ones listed... Here's their number 1-877-438-6938
  15. There are a couple places to rent atvs. But depending on where you are coming from I can help you better. Which side you coming from?
