yama_dog_350
Contact Methods
  • Website URL
    http://
  • ICQ
    Melbourne Fl.
  • Interests
    whatever
    2001 white + black yamaha banshee 350 - ada racing head 21cc domes, jp nerf bars, degree key, cpi in frame drag pipes, read spacers, rad valves, dyno jet kit, boost bottle, k&n filter, outer wear (filter and air box), 2-20 fin cooling tubes, e-z drain plate, high volume impeler,+2 +1 a-armes,works tripple rate shocks with rezies,hide key,and many coming.
yama_dog_350's Achievements
  1. My bikes in Michigan Im in the military and assigned down Here.
  2. in the dunes on the trails and the only thing i know aboput them is they can only be found at one web site dick so back off for all i know its a bs part like the boost bottle
  3. well what do they do and are they worth it?
  4. Well since you guys dont agree with what alba told me i bought the v-force 3's today where do i get the reed stuffers?
  5. alright i was just talkin to guy at Alba and he said to switch back to my stock reeds because it will produce more power with the stock than using a after market reed I see one of you have already recomended that as well. The guy worked in the performance shop anybody already try this what was your success i guess ill try it the only thing i could loose is the time to switch um back out.
  6. Thanks for the info. But what do you mean by stuffers???
  7. Alright i bought the timing plate, 34mm keihin carbs, new throtle cables and k+n's and pre filters today. I send my jugs off to get ported on friday. Does anyone know of a good port shop if not ill just send um to this shop next to home in michigan. Should I upgrage to the v-force reads and if so the 2's or 3's has anyone ever heard of the modquad intake system if so should i get the split or togeter one or should i go with the pro design intake or somthing else. My bike already has cool head, or ada racing head i have both with 20's for domes, -cpi in fram drag pipes -hot rods and 4mm stroker crank -weizco pistons -boost bottle -rad valve reed spacers and cages -no air box k+n filters on carbs -high flow water pump thing -over sized radiator -lone star +2 steering stem -lone star +2 rear axle -role design +2+1 a-arms -works triple rate front shocks with reziez, works rear shock with rezie, designed to my weight and dune riding -skid plate full chasie -ez drain plate -barnet dirt digger clutch and springs -hinson presuer plate -hinson clutch basket
  8. parts list: -cool head, or ada racing head i have both with 20's for domes, -hot rods and 4mm stroker crank -weizco pistons -boost bottle -rad valve reed spacers and cages -no air box k+n filters on carbs -degree key -high flow water pump thing -over sized radiator -lone star +2 steering stem -lone star +2 rear axle -role design +2+1 a-arms -works triple rate front shocks with reziez, works rear shock with rezie, designed to my weight and dune riding -skid plate full chasie -ez drain plate -barnet dirt digger clutch and springs -hinson presuer plate -hinson clutch basket I plan on dune riding and maby a trail here and ther
  9. The expansion chamber (fat area on pipe) is used to draw fuel into the combustion chamber. The power valve closes at low rpm to provide consistant power so you dont have to down shift.
  10. no air box k+n filters. Also i was gona pay about $3,500 to trinity so thats my budget also iget parts at cost. Also bansh-eman what do you mean by matching parts.
  11. correct i have tork but less speed
  12. So ditch the boost bottle, degree key, and reed spacers. Get the 34 carbs, port job, and timming plate. Is there anything else that anyone can recomend to get this thing moving.
  13. I had a 4-mm stroker instaled in my shee thats when I lost power. The moter has only had a cool head put on it with 20cc domes, cpi in fram drag pipes, rad valves, reed spacers, degree key, and a boost bottle. I'm wandering if 34mm carbs and a bore job with port would fix the problom. or should i jast pack the motor up and send it to trinity.
  14. Got a 97 Polaris Indy Storm 800 tripple the oldest machine in the inventory.
  15. Natural solection I like to belive in that. ignorance and laziness are unforgivable from what ive seen they had there chance to leave they didnt take it there own fault. besides who the hell builds a city at 7 foot or whatever the hell it is under sea level and expects it not to flood like that. I shure as hell wouldnt live there. i say implament martial law you want to act like animals let um be treted as such
