motox570
    03 suzuki rm250 03 kawasaki zrx1200
motox570's Achievements
  1. oops, sorry about that. stock is 25. had a brain fade. C
  2. if all you have for mods are pipe and an air filter, wow your way to rich. you should be 260 or 280 (with mikuni's i'm assuming) stock 30 pilot and about 1 turn on the air screws. also is your snorkle off? if not it should be. C
  3. make sure your choke crossover tube is hooked up. also syc the carbs with the dots in the sight glasses. what exactly is the compression readings? if you have a hole in your piston you will have very low compression, doubt that's it or it wouldn't run at all on that side. C
