illboogie
Everything posted by illboogie
  1. eastcoastatv.com does both PC and chrome and i went to check on my arms cause the tie rods are still gettin chromed and i am real picky these things came out 4million times vetter then i imagined they did some nice work
  2. the diff between them is a wet kit injects fuel and nitrous at the same time where a dry kit just injects nitrous and relys on the vehicle to supply the extra fuel. ive had nitrous on alot of cars and stuff and i would go with the wet kit cause it alot safer because it supplies its own fuel. a dry kit im sure will work good but if for some reson you dont get enough fuel to mix with the nitrous you will run lean and burn somthin up
  3. does anyone know where i can get replacement heim joint for my alba a-arms?
  4. i only use bel-ray h1r and it works real good
  5. im in the process of doing the same thing right now and i just put everything in bags and label it like all the a-arm bolt in one bag and label em
  6. yea i like purging
  7. tanx meat im gonna look into that right now i think im just going with the barnett and hinson basket let you know how it work sout
  8. thanx for the help
  9. yur friend is right if you drink milk b4 you go drinking you wont have a hang over cause yur gonna puke all the alcohol out. i usually just wake up take 3 tylenol extrastrengh gatorade and 3 redbulls yull be fine in a 1/2 hr
  10. i meant ebc so kevlar is the way to go?
  11. thanx man yea i got the allen head bolts already im lookin at the bec clutch kit anyone how they are and whats the diff between the race on and the regular one and i heard you need to soak the plates in oil do i soak all of em or just the steel ones?
  12. im gonna be replacing my clutch on my 96 banshee and was wonderiig what parts i need or does it come in a kit? probably gonna need a new basket alsowhat kind do you guys recommend? i do alot of everything riding and want a good HD clutch to hold up.
  13. kinda want to sell em a s a pair but ill let you know
  14. it has somthing to do with my avatar
  15. stock banshee lights for sale small crack in plastic guard over the lens. $35
  16. i went to ebay and typed in banshee bearings and got a whole front set pretty cheap
  17. or you can get a photo program and it will let you edit and everythiing else. not to sure of the names of em though
  18. dude that is the gayest way to pull a wheelie klotz being tht you spin try not dumping the clutch but more of a slipping it out until you feel it start pullin then yank back and give it some gas.
  19. what kinda oil
  20. sand scotch clean paint. remember if there is any shiny spots on the plastic after sanding you have to sand em or the paint wont stick
  21. if its separating you missed it with the sand paper you want em to look dull when yur done sanding and sand all the shiny spots you see and you can wipe it down with a tack cloth from a parts store
  22. 400 grit wetsand,scotchbrite the red one sand it wet with that use alot of water ,the purpose of wetsanding is so debris doesnt build up on the paper and scratch the plastic and then wash it real good
  23. thats all french to me i have no idea
  24. what kind are mine there stock
  25. whats pwk
