Do you need the ones that have a larger bolt pattern then like a 1996 if so ive got some off a 1990 they have a wider span i took them off and put some new ones so i could fit all my tires on them
let me know
Did you have a stroker crank? How much do sleeves run for the cylinders? ANd is it the cylinders with the head and the reed cages and all the stuff that comes with it?
let me know
Come to the Sand dunes this weekend (little sahara) ill be there. ill have to see what happens when october comes around ill go 1 week out of the month. what time in october are you going down? WHat are you going to monticello for?
If you messed up the ports when you were cleaning them up even just the littlest bit it will screw it up making you loose power. How much did you take?
your first mistake is mixing your 110 gas with pump gas that wont fix the bog but mixing your gas just ruins the 110. 110 is leaded and the pump gas is unleaded you should not mix it. What your mix on oil? And what do your plugs look like?
i was taking trying to get a blaster started that someone had cut the key off of and i did the same thing i was trying to find the wires to touch together i found them after being shocked 4 wheelers but out some POWER
in the sand id get 8 paddles haluers with some douglas .125 wheels and some hauler mowak fronts on .125 also Id get some v-force reeds also they help with low end and better throttle response id get a dune port also plus what you have listed and it will be good through the dunes plus go up the hills pretty good also
I live about 10 miles from the place that actually makes them CPI racing i got my drag pipes chromed for 490.00 cpiracing.com and there inframes aren't much more
you must need to sand them more. But ya krylon fusion seems to flake if you scratch it in one place then it continues from there like if you do the tank cover your seat will rub on it and take it back to the original color
