SICK BOY
Everything posted by SICK BOY
  1. Thanks for looking out.
  2. They look pretty cool.
  3. What seals this?Do you just use the stock piece of rubber between the cover and the insert?
  4. I have Pro Tapers CR low bend.
  5. Give up his name,and call the guy out.
  6. I had a dirt digger clutch and spring kit,and the clucth was hard to pull and snapy.I have heard a lot of good stuff about the Tusk kits,and i will try one next time I need a clutch.
  7. I reverse bleed my front brakes,Here's how---- Take the master cylinder cover off and make sure the rez is full.Place the cover back on,but don't put the rubber piece in and don't put the screw in.Grab the lever and pump it for about 3 mins.Then use a rope,or zip tie to hold the lever to the grip.Come back in 2 to 3 hours and remove the rope/zip tie and pump it for another minute or two and tie the lever to the grips again.Let it sit over night and when you wake up they are bleed,put the rubber piece back in the rez and tighten the rez screws and go ride.
  8. Great looking house,congrats. Dosen't look like the neighbors are going to be a problem.
  9. Congrats on the new quad,I bet you won't miss the 400ex a bit.
  10. Yes,young grasshopper is learning well.
  11. You'll get more replys if you post in the wanted forum.
  12. Banshee stock front shocks are non-rebuildable.If you need a set and don't have the cash for aftermarket ones post in the wanted forum.You can probley find a good used stock set for cheap.
  13. What brand do you have?Most of them go from steering stem to the front of the frame under the front plastic.I cant find any pics of my old one,but do a search and you'll find some pics.
  14. I'd clean the pipes up,and put new o-rings in them.I don't see how it would be gear oil coming from the exhaust,or do I understand what it would have to do with crank seals.
  15. I said Taxi Driver was my favorite movie in my earlier post,I just wanted to add Clock Work Orange as a close second.
  16. I agree,then you'll find out whats better suited for you.
  17. I might bid on that,it would make a awsome ashtray for the garage.
  18. Those tires are toast.
  19. Great job on the grill,both quads are A-OK with me.
  20. I have stock front lines,pay shipping and there yours.
  21. I hope you get a hold of the guy,you got a great deal.
  22. This is the for sale forum,post this in the wanted forum.
  23. That's fricking nuts !
