89 bansheedude
Everything posted by 89 bansheedude
  1. i got 593. jayare
  2. tack weld them back. be hell if that came off, you might not be living. i wouldent ride it untill you get all the welded. jayare
  3. id say thats why he is getting rid of them, or trying anyways, someone might need them. jayare
  4. if you do mostly trail like me, then its you rotors that are fucked, they are not smooth causing the pads to be like sanded down really fast. its usally the rear that does this. try going with a new wave rotor, there sopposed to cut down on the dirt and mud biuldup on the brake, then gets some hard pads som they last longer, cost more but last longer. hope this helps you. jayare
  5. if you read alittle closer, he has already contacted trinity. he needs some help, i have no clue either. we tryed contacting wiseco but no luck with that. jayare
  6. tats, i think they got me on the work scedual now. you still want to hold them for me? ill talk to you more about it. jayare
  7. well........................bump
  8. im not much on works, i think i might go with some tcs but dont know what the price they run. jayare.
  9. well after getting my +2+1 arms, i am in the market for some front shocks. what i need to know is all of your alls oppinion on what ones are the best or you like the best and a website for me to view them at. yes i want some good ones but i dont do just mx, i dont some mx, alot od trail riding and open field. let me know. jayare
  10. i think i have found some, is your nickname goonie as well? thats what my buddys call me. jayare
  11. yes, one of my good friend b-day is also today. jayare
  12. really really easy. manual helps but really not needed. jayare
  13. i am in need of some front calipers, mine are both striped at the bleeder screws. thanks jayare
  14. im trying to get the piston out, its stuck in all the way and wont move. need help to free it up so it will move. thanks, jayare
  15. im still working on the front brakes and i figured out why they wont bleed. how do you get the piston in the brake unstuck? i pushed it in and it was really hard and i cant geet it back out. i think is about stuck haha. so how do you all get it unstuck? thanks, jayare
  16. how much do you all pay for them lowering links? hell i make mine myself. i have pics but i dont have a good plase to host them from but i will try. jayare
  17. ok, i will try that tomorrow when i get off of school. thanks sredish. ill post back to let you all know how it goes. thanks, jayare
  18. yes i have a manual but its at a buddys house. allright see it dont get any pressure on the leaver at all, i can pump it 50 times and it feels the same on the 50th as it dont on the first. the piston on the brakes isent coming out also. but when i crack the beelder valve air and fluid comes out. im stumped. thanks for the reply. jayare
  19. i pray for you tats, your a good man and a good friend. wish you good luck also. your crazy buddy. jayare
  20. well josh you need to come over here and do it. its not getting any presser at all. feels just like pulling a lever with it not connected to anything. i really need some help. thanks, jayare
  21. i need some detailed instructions on bleeding the front brakes, i have searched and they dident help me much. i have been pumping holding the lever and cracking the valve air and fluid comes out but it dont gett no pressure or compress the piston. let me know step by step how you all blled your front brakes. and no i have no mity-vac or whatever. fluid are threw the lines. hellppppp. please. jayare
  22. i have some, i just bought me some yamaha taper balljoints so i dont need them anymore. make me and offer. there in really good shape. jayare
  23. well yes i have the lid on the airbox but the snorkel is removed and i have 2 3 to 4 inch holes drilled in the lid. i also have a hotrods crank and rod if that matter, and i believe the head has been milled some. jayare
  24. well i have pjw28 kehin or however you spell it carbs, and they was for my stock jet. over the winter i have added some procircuit pipes and silences, ported cages with tdr reeds and i have.060 bore with wiseco pistons if that matters. needing help on where i should start the jeeting at or what jets i might need to get. i havent ever jetted carbs before. and i dont know my elavation i live in tennessee in the valley. thanks, jayare
  25. they where working, and i tryied to remove the orig.jpg. or whatever and it said the pics cant be posted from a domain or something like that. they work sometimes, just go back the try it again. jayare someone post them for me or give me a good free site to host them from. thanks
