I just got back off of deployment and have run into some problems with my 'Shee. I had it out at the track and ran it fine for two days in somewhat muddy conditions and then last Friday as I took it for a spin and it died and wouldn't start again. We tried replacing plugs, tapping on the bowls to loosen floats and nothing worked. I trucked it and left and a half hour later it started up but then bogged down and stalled after about 10-15 seconds of running and wouldn't start again. When you try to start it will somewhat backfire out the back and try to start but never quite get going. Here are some of the things I've tried:
-New Plugs
-Drained gas and remixed at a little leaner mixture (32:1 stock, I went 36:1 with mods thinking it might be getting too much oil)
-Took the carbs apart and cleaned them, didn't really see any dirt though
-Air Cleaner is clean
-TORS equipped
Whenever I empty the carbs out by tipping the 'Shee up and kick it to flush everything out, she will start for a few seconds and then die and then it's back to kicking it over and over and watching fuel come out the hose at the bottom of the bowl. Just wondering if anyone has any suggestions or has had the same problem and might know how to fix it. Thanks in advance!
See ya out there!
Lucas
