mxshee
Everything posted by mxshee
  1. Make an offer.
  2. The Rebel, I have a Trinity CV 2 into 1 intake setup, but it is with the 35mm carb. Let me know if you're interested and I will get you some pictures. mxshee
  3. Dmcbanshee, I have some brand new chrome PTR mids that I would like to get rid of. I don't have any pictures right now, but I will try and get some this weekend. I just bought the pipes when I rebuilt the banshee a couple weeks ago, but in the meantime I decided to get a new YFZ, so I'm going to get rid of the Banshee parts. Let me know if you're looking for anything else, because I will probably have it. Give me an offer on the pipes and I will try to get you some pictures in the meantime. mxshee
  4. I do not have an adjustable stator plate or advanced key. I will try switching the plug wires and see what I come up with.
  5. The plug is dark, but not fouled. I can't understand how it would be a jetting/mixture problem, since one fires fine and the other is missing. How do I troubleshoot the ignition/timing? My jetting for the 35mm setup is 180 main, 48 pilot, 4th needle position, and 2 turns out on the air screw.
  6. I just rebuilt my entire Banshee motor, new Wiseco Hot Rod crank, all new bearings and seals, Wiseco top end .040 over, a coolhead, shift star mod, flywheel lightened, and new PTR mid pipes. All of that stuff is new for the rebuild, and I am also running the Trinity 2 into 1 carb, 35mm. I mixed up some new gas with a 16:1 mixture with Klotz benol for the breakin period. I fired up the bike and ran it through a couple of heat cycles and everything seemed to be fine. Last Saturday I fired it up again to start doing some low gear break-in riding, and that is where the problem started. The left cylinder started mis-firing. The right was firing just fine, but the left didn't seem to be firing all the time. I am wondering if this could be an iginition problem, or if I've scorched a ring or something. I did a leak down test after putting the engine back together, and I only lost .3 lbs over 6 minutes, so I'm cofident that I don't have an air leak. Also, I don't think it's intake because of the single carb and one cylinder is firing fine and the other isn't. I know that someone on this site will be able to help out, so please give me any suggestions on what to check. Sorry this post is so long.
  7. mxshee
    Ptr Mids
    I'm looking for some PTR Mid pipes and silencers if anyone has a set. Chrome or not, I don't really care. Please let me know if any of you are looking to sell a set. Thanks
