Holyman Posted January 7, 2005 Report Posted January 7, 2005 Here is a tech tip and measurements for installing a grease fitting in a Banshee swingarm. The Grease fitting can be bought anywhere. It is a 1/4-28 screw in fitting with a nylon washer underneath to make sure I could set the angle of the grease fitting. I drill the inner sleeve to allow some of the grease to get to the bolt in the event I ever have to take it apart. Quote
bansheeigo Posted January 7, 2005 Report Posted January 7, 2005 (edited) Where can i get those nylon washers at? Edited January 7, 2005 by bansheeigo Quote
Holyman Posted January 7, 2005 Author Report Posted January 7, 2005 Any hardware store has 'em. Total cost is about $1. Quote
Holyman Posted January 7, 2005 Author Report Posted January 7, 2005 That's 2" from the end and about 1/4" up from the weld just to make sure there's no probs with tightening down the grease fitting. Quote
BansheeBoy17 Posted January 7, 2005 Report Posted January 7, 2005 I'm so doing that to mine... thanks agian holyman! Do you know if your goin to the FMX show yet? I'm goin to the saturday show at 2pm. Quote
Holyman Posted January 7, 2005 Author Report Posted January 7, 2005 Don't know about FMX yet. I'd like to go but income is a little light right now. Hey if you can talk your folks into refinancing their house with me I'll even buy YOUR tickets Quote
Ryda85 Posted January 7, 2005 Report Posted January 7, 2005 i know this is alot of questions...just wanna make sure i do this right so one zerk right where you posted and a hole through the sleve...or just through one side of it and lastly do i have to make some sort of vent hole to allow excess/dirty grease to escape and also let me know when its full Quote
Holyman Posted January 7, 2005 Author Report Posted January 7, 2005 i know this is alot of questions...just wanna make sure i do this rightso one zerk right where you posted and a hole through the sleve...or just through one side of it and lastly do i have to make some sort of vent hole to allow excess/dirty grease to escape and also let me know when its full 303157[/snapback] Yep, only 1 is needed 2" in from the end and .25" from the weld. You only need to drill the hole thru 1 side of the sleeve. The excess grease will come out fromunder the dust caps. The swingarm bearings are not sealed so pressure is easily released when you pump in the grease. Quote
Ryda85 Posted January 7, 2005 Report Posted January 7, 2005 great....ill do this tomorrow...how many oz of grease fills it up? do you have a walk through for the carrier? Quote
Holyman Posted January 7, 2005 Author Report Posted January 7, 2005 great....ill do this tomorrow...how many oz of grease fills it up? do you have a walk through for the carrier? 303161[/snapback] The same amount of licks as it takes to get to the Tootsie Roll center of a Tootsie Pop... The world may never know The carrier is about the same except I use a press in or Hammer in fitting instead of threading. Drill a .25 hole, put a press in fitting in the hole, Put a 1/4" deep socket over the top of the fitting and hammer it in with a couple sharp blows. I also drill the inner sleeve. Cool thing about doing the carrier is that you can put the zirk where ever it's convenient. Quote
fixitrod Posted January 7, 2005 Report Posted January 7, 2005 I put one in the dead center of the swingarm. Yours is more convenient. Quote
Fireman-hott Posted January 7, 2005 Report Posted January 7, 2005 I'm so doing that to mine... thanks agian holyman! Do you know if your goin to the FMX show yet? I'm goin to the saturday show at 2pm. 303152[/snapback] Hmm I thought the shows were at 7pm. I'm debating going, its what Feb 17th-18th or 18-19th. What did your tickets run. Quote
fixitrod Posted January 7, 2005 Report Posted January 7, 2005 I think they hit your for $15 to park too. If it's the same show I meet holyman at once. Quote
