ok, pull the filter off turn the fuel off, pull theplug out and clean out the fuel you put in the cylinder. with the filter off so you can see the back of carb put a squirt of fuel in the carb, not enough to flood it, see if it hits, if it doesn't hit and you have good spark it's either a broke valve, timing chain is too loose, or a electrical problem, if the above doesn't work, disconect the kill switch, see what happens. if that doesn't work disconect the key switch and jump it with a wire......
if you put jumper cables on the battery will it start over with the start button?
