The instructions for installing this axle are pretty bad. I just need some help with the placement of everything. I already got the old axle out (it was a PITA). I know I dont need the small spacer, just the large one. I also have the picture of where everything is supposed to go. It doesnt show which direction everything goes which seems kinda dumb. I have the 3 peice lock nut, 2 cir-clips, large spacer, I think that its. If anyone could help explain this it would help out alot. Thank you for your time in advance. Yes I did a search and I will just ignore flamers.
Edited by jlsparky7
3 pice lock nut on the left and one circlip inside. then use the metal ring on the right side after the disc brake hub and put a circlip inside that also.
I think this is how it goes, I just got mine back from rockymountain and have to install it again.
If something doesn't make sense sorry I have all the pieces in a bag and I am not 100% sure how they go again
Yup, thats how mine went in. :thumbsup:
They go like this then. Assumming you have the cir-clips in the slots?
Brake side:
Sprocket side:
No not yet. I was all worn out after fighting to get the stock axle out. I think I might hold off and throw some new bearings in while im at it. Im also gunna install a grease fitting on the carrier.
Edited by jlsparky7
  • 3 weeks later...
I got it installed with the new bearings. Works great, thanks for all the help guys. Ill be throwing a grease fitting on there as well. Excellent suggestion. I dont know why they didnt design it that way to begin with.
Man I love RMATV with there cheap prices and fast shipping :-)
The grease zerk is a great mod, but it won't do you any good, unless you pull the inner seal, out of each bearing. Another thing, when using the grease gun, don't keep pumping until grease runs out past the seals. Just grease it, until you feel some pressure at the grease gun handle.
  • 4 weeks later...
I got mine put in and noticed one of my c rings are bigger than the other and serve absolute no purpose... Anyone else have this problem, i sent an email to rm.com and will update you all on what they do for me..
