NECK Posted February 13, 2006 Report Share Posted February 13, 2006 I'm installing the Trinity 2 into 1 C.V. carb set up and the throttle cable that came with the kit leaves alot of play at the lever, even at the tightest adjustment you can make. Did any of you guys that run this set up have the same problem? Is this supposed to be this loose? It takes probably 3/4" of movement before the slide starts to lift. Thanks in advance for any feedback. -NECK Quote Link to comment Share on other sites More sharing options...
Wallrat Posted February 13, 2006 Report Share Posted February 13, 2006 Are you running a Terry Cable (stainless braided line)? If so that's the same problem I had. I had to change the routing a dozen times just to get it to where it was barely useable with all the adjustments maxed out. I was able however to get the free play within acceptable limits. Best advice I can give is to get a motion pro cable for a blaster. Quote Link to comment Share on other sites More sharing options...
NECK Posted February 14, 2006 Author Report Share Posted February 14, 2006 I finally got it to work. Thanks for the tip on the Blaster cable. I'll keep it for when this braided line stretches. Quote Link to comment Share on other sites More sharing options...
