Turbo on a banshee
bluefrog
there is alot more to it than just mounting the turbo.....i doubt the turbo that you have will work.....most use very small garret turbos or somthing similar. a banshee motor doesn't have enough exhaust volume to even turn the turbo that you have fast enough to create boost. If you want to go this route you'd be better off having a&s or tyson set you up with a turbo kit for your motor....also the cylinders on your motor must be unported.
