Can you get a pic of the carbs, if their stock carbs they should have a rubber tube/hose running from carb to carb that is for the choke. If they are stock and you dont have that it wont run right. Does your carbs look like these with or without the funky things on top otherwise known as tors, the yellow tube is what Im talkin about but yours wont be yellow.
Does yours have the choke handle on the side like these? Use the zoom down in the right bottom corner to get a close up.
yes i have the choke and it didnt have the tube but i noticed it yesterday and found a hose and made it go to both carbs
