Your stockers really should be fine with a play port and FMF's, don't know why your at 380mains though. Have to be on the hairy edge of runnin your bowls dry with that big of jets. Need to figure out what is going on there :shrug: For your mods, if you insist on getting carbs...I would recommend 28 or 30mm TM Mikunis. 28's will retain more bottom to mid power, and the 30's will give you more mid to top power with a slight loss in the bottom end.
