It depends on the motor builder. EVERY motor builder has a different way of doing it. Mine on my 14 mil was to do 3 heat cycles, then do a break in pass. Meaning, drive it like you stole it.
Where in upstate NY you from?
I always recommend to do 4 heat cycles then retorque the cylinder and head studs. Then perform a thourough plug chop or series. Then ride it as you would normally.
