tundish2800 Posted August 11, 2008 Report Posted August 11, 2008 When i start it it will idle fine then the rpms start to climb and climb and i have to shut the shee off. carbs are good put good coil and cdi off other bike still does it? anything else i should look for? Quote
mercury65 Posted August 11, 2008 Report Posted August 11, 2008 also check to see thats its not runing to lean at idel, if i trun my fuel off and let it idel, when the carbs run dry both my shee's will do that same thing. did you do any work on it b 4 it starting doing it, let us know the hole story about the bike so we can better help you. Quote
2strokespirit Posted August 11, 2008 Report Posted August 11, 2008 air leak or your float levels are way off.. Quote
tundish2800 Posted August 11, 2008 Author Report Posted August 11, 2008 the carbs came off my other bike that i blew the motor in. that bike would sit and idle all day long so i dont think it would be the carbs. Quote
