1st thanks for looking at this post
ok guys i will make it short
mods- t-5 pipes
pro design foam air filter.. no snorkel using lid with toomey air vents in lid and box
elevation- 2050 feet
temp- betweeb 68 - 86
fuel ratio - 32:1
im currently running 280 mains, stock pilots (i ordered bigger pilots 27.5 & 30)
also with the needles that came with the toomey kit and the clip on the #3 groove
i would like to also find out how many turns out of the air screws if they were all the way in?
are mains too big or small? leave stock pilots? fuel ratio? etc
please reply and thanks any feed back will be great
much appriecated guys
jack
Do a plug-chop, you can find out how in the jetting FAQ thread.
Mains sound a tad big for having the airbox on, but it should run well where it's at.
Why do you ask about the jetting, is the bike running bad?
its not running the best on idle actually it wont idle... and i wont be able to do a plug chop until a couple of weeks.. so i really need a rough idea wre im at
thanks
try 290 on the main go 27.5 on the pilot and 1-1/4 - 1-3/4 in the airscrew see if that helps
oooo go back to the stock needle, place it on the 4th from the top try this out and see what happens
thanks i will try
sorry to question but what is difference between the stock needles and the toomey ones? and also with the air screws do i undo them untill they came out then start turning them in or wat?
thanks for the feedback
280 mains should be fine, if anything a little rich with your setup and elevation and summer temps
dont put bigger pilots in it , leave the stock ones
the toomey needles run great in mine on the 3rd clip down from blunt end
do you have tors removed with real idle screws? to set your air screws turn them al the way in till they stop, turn your idle screws up a little higher than normal, turn air fuel screws out 1/2 turn at a time in each, wait 10 seconds, repeat, do that till u get the highest idle out of it, if you have to turn past 2 turns your pilot is too big, less than a turn and its too small, turn your idle screws bck down, make sure the carbs are both in sync, hope this helps, only u can ride it and see for sure though
you never mentioned how your banshee was running either... does it bog anywhere? ect..
Edited by Michael Jackson
no i dont have have the tors removed yet hoping to do so in the future.. im spewing i just came back from yamaha and i friken spent $80.00 on bigger pilots (27.5) and larger mains hahah only if this was posted in the am hahah..
well wen i thought i jetted it (before i read the posts on jetting) it was running rich so i placed the clip 1 groove higher (#3) and i didnt play with the air screw, it blew less smoke but in one exhaust it was spittin a lil bit of raw fuel.. a couple days after i played with the airscrews and then it all went to shit wouldnt start bog on idle, no idle etc... tomorrow i will patiently work on them, do wat you said and let ya know..
stick with stock needle if i remember correctly the toomey has a fatter taper so it doesnt matter if you are running a bigger main you could still be running the bike lean because of the needle.
call 1818-500-7263 for good deals on anything banshee guaranteed.
check out my bike on the exact setup i told you the only difference is that i bored out the carbs to 28 and since im running dual k&n's my main jet is bigger. but the rest of the setup exactly the same. ooo and this is dumont so its more or less the elevation you talked about.
i will try both and see the difference.. nice clip u were smokin... come down to AUS i will line ya up hahaha but i will need to put side mirrors so i can seee ya ... jokes lol
p.s if i was to buy aftermarket reeds what adjustments would i need to change with the jetting?
and any recomendations on to which are the best ones to buy for me..or should i wait a bit go all out and buy the the v force 2 or 3 cages and reeds?
Edited by jack350
haha you'd better have something pretty crazy or get ready to repaint ur front end hahah.
no adjustment needed for the reeds all they do is control the flow better and atomize the mixture better like when you have water in your mouth and spray it the tighter it is the more finer the spray same principal. but the v force clear up the midrange as compared to the stock so its a win win you cant really go wrong
thanks :thumbsup:
