My front end has what i'm guessing is +1 or +2 wheel spacers on it. The front end is wider than the back and I'm wondering if thats a good or bad thing. I hear banshee's tend to go ass end over front end in most flips so I guess the spacers would help. While I'm asking i figured id ask about a-arms also...does +2 +1 mean top arm is +2 and bottom is +1? Just wondering. Thanks
take that shit off i had them on my shee from the guy i bought it from and there no good because theres a couple little lips on the hubs the hold onto the rim and with the spacers its not holding onto that and also the bolts are longer so there less strong i just took mine off a couple weeks ago and got the stock studs and lugnuts and i ordered aftermarket a-arms. i didnt trust those spacers because if you turned a little bit it would jerk the wheel. i say take em off. 2+1 means to inches wider on each side and 1 inch foward
Awesome. Thanks for the help. If I took the spacers off I'm guessing id need the stock bolts?
yeah youll need the stock studs and stock lug nuts because they have special grooves but when you change them youll notice the wheel wont jerk it self if you turn a little or hit bumps.
