saw these pistons and i wanted to hear everybodys opinion. i beleive theyre wsm brand. i cant find wiescos fro this price. i think it was 30 bucks for a std piston,ring,and pin.anybody run these pistons?
I can't beat that price. I source mine through Western Power. $65 is a hell of a deal considering list on them is $114.99 each. I usually recommend replacing the bearings, depending on hours, wear and budget. If it's a low hour engine in for porting only (not burned down) and the owner is on a tight budget then I'll reuse them. But, they are only @$10 each.
i think that im going to replace the bearings anyway because it was never opened up before. so reusing bearings from 98 will probably give me problems. im trying to cut corners as much as i can with this but id rather spend the 10 bucks and replace them anyway instead of replacing a crank when it blows apart at 9 grand. as of right now its going to cost me 275 bucks to get it where i want it. it aint that bad.
the one thing that i dont understand is that everybody has top end kits but none that i saw includes needle bearings. you would kinda figure they would.
ive just bought the vitos piston set up they do come with the bearings, i actually ended up with two sets of them becouse i bought a crank from them as well, not sure if this is a bad oman or not well see.......
