Hey, I would like to purchase an 18/38 setup if anybody has one. I can't seem to find them online anywhere. I have a 40 rear from Sprocket Specialists, but I would like to go taller. If anybody has either, please let my know ASAP. I will paypal you the money and you can overnight it to me.
Thanks
Thanks
You might have to go with a honda rear sprocket hub..I think you can get a 38 in that. Or get higher ratio primary gears.
Higher primary gears is something I will be looking into shortly. I just want to see if this setup gets me to where I need to be in the 1/8th mile. Any suggestions on what sprockets I should start out with? This is what I will be running;
14mil Cheetah with a 73 bore
41 Mikuni alky
1-5 override
20" American Racers on a 10" rim
All the other important stuff is in my sig. Total race weight should be under 280lbs.
Thanks for the help.
Nevermind, I just paid an arm and a leg through Sprocket Specialists.
Did you know that they have 74 tooth rears for the banshee!? Hahaha, that bitch would stand right up at the crack of the throttle!
Thanks
Vito's performance has the 38 rear, not sure about the 18 front.
Thanks for all the help guys!
But Just so everybody knows. Sprocket Specialists Have everything for a 1987-1988 Banshee, to include 11-19 fronts and 37-74 rears. They also have 11-19 fronts and 38-74 rears for the 1989-2004 models.
Their chart on their website is a little hard to read, but I found it.
