jerseyrider Posted July 14, 2008 Report Posted July 14, 2008 i just bought a banshee from reading pa. i live in south new jersey and the guy i bought the bike from said i would probably have to rejett the carbs(35mm i think,so he said) and i need to know what the right jetts would be thank you IM NEW TO THE SITE ,CAUSE IM A NOW BANSHEE OWNER i have a worked 450r too....but i wanted more power thank u alll Quote
Misssppelllleddd Posted July 14, 2008 Report Posted July 14, 2008 Ok so you want more power from the intake? :biggrin: Remove the airbox and get an external airfilter setup. You will have to check your main jets and get a set for the brand of carbs you have. I would recommend 1-2 sizes bigger. The more air you get the more lean it will run. After that your should run the shee through the gears and do a spark plug check. When you check the plug you should check the rim of the spark plug. NOT THE PORCELAIN. You want an even tan color. A white color will mean it is too lean and a black color will mean it is too rich. The rim will be wet from time to time so don't be too alarmed from that. Keep in mind 2-strokes are different than 4-strokes. The better the mixture the more hp you get. You can also add some addons like some reed cages and some reed spacers for the intake mods. What else does it have for engine mods? And how do you want to ride it? Quote
