06BaNsHeE Posted July 14, 2008 Report Posted July 14, 2008 i was thinking about getting a rap 700 but i love my shee the power is crazyso im just gonna due up the shee instead of spending 8k on the raptor i see your tryin to get rid of your z and the 700 so i guess u like the fell of the banshee over the 4 stroke I was going to get rid of them to get a drag banshee but now Im prolly keeping them.This banshee will prolly never see a trail in its life lol I have two good trail bikes.If ALL you do is trail ride and mud ride I would get a raptor.Stock on stock and piped vs piped and bolt on vs bolt on the raptor 700r is faster. Quote
Wildcardracing Posted July 14, 2008 Report Posted July 14, 2008 I'm not sure why you would even retard the timing... Power adders, ie: nitrous. The only reason I could think of running retarded timing. More than likely the previous owner didn't know what the - and + meant...lol As for the problems with the pull in the higher gears, yes it could easily have been the cause. Would have killed what little low end your shee might have had. Quote
T-daddy Posted July 14, 2008 Author Report Posted July 14, 2008 Power adders, ie: nitrous. The only reason I could think of running retarded timing. More than likely the previous owner didn't know what the - and + meant...lolAs for the problems with the pull in the higher gears, yes it could easily have been the cause. Would have killed what little low end your shee might have had. could it also make it a little harder to start the bike with the timing being retarded Quote
T-daddy Posted July 14, 2008 Author Report Posted July 14, 2008 could it also make it a little harder to start the bike with the timing being retarded ok i started the bike up today it sounded funny after going +4 it reved faster it was like really high idle so i lowered the idle then it sounded normal but when i reved it i noticed when it calms down to idle i hear a rattle coming from the topend not loud but i noticed is it detonating or is that a sound it gets when u advance the timing Quote
dajogejr Posted July 14, 2008 Report Posted July 14, 2008 Put the plate to 0. At 120 PSI (if that's an accurate reading from an accurate gauge) with pump gas it shouldn't detonate. But, if you put a few steel ball bearings in the motor when it's running, that's what detonation sounds like...not good. Do you know what size jets are in the carbs?? Quote
T-daddy Posted July 14, 2008 Author Report Posted July 14, 2008 Put the plate to 0.At 120 PSI (if that's an accurate reading from an accurate gauge) with pump gas it shouldn't detonate. But, if you put a few steel ball bearings in the motor when it's running, that's what detonation sounds like...not good. Do you know what size jets are in the carbs?? oh ok it doesnt sound like that but i put it at zero and i can still here it but i guess its nothing it may be something else rattiling but i no medal is slappin medal somewere i just have to find it but i have 280 mains in and 25 pilots for fmf pipes and no lid on airbox should i go up on the main and pilot for those mods do i have to rejet when i add timing Quote
Erwin8r Posted July 14, 2008 Report Posted July 14, 2008 oh ok it doesnt sound like that but i put it at zero and i can still here it but i guess its nothing it may be something else rattiling but i no medal is slappin medal somewere i just have to find it but i have 280 mains in and 25 pilots for fmf pipes and no lid on airbox should i go up on the main and pilot for those mods do i have to rejet when i add timing Leave it alone for now and go ride it! Then report back... Quote
awaitedshee Posted July 14, 2008 Report Posted July 14, 2008 um just puttin out there but the metal on metal rattle could be the kick starter lol. :ermm: Quote
T-daddy Posted July 14, 2008 Author Report Posted July 14, 2008 um just puttin out there but the metal on metal rattle could be the kick starter lol. :ermm: lol i made sure it wasnt that Quote
T-daddy Posted July 14, 2008 Author Report Posted July 14, 2008 lol i made sure it wasnt that figured out the rattle me being in a rush to ride i didnt put the left pipe on tight because i was cleaning them but the pipe was hitting the head and rattiling i fixed it and rode it with the timing at 0 but im gonna try +4 2morrow but at 0 it was a big difference it gets up :woot: i was missing out on the true power for 2 years now Quote
Wildcardracing Posted July 15, 2008 Report Posted July 15, 2008 Glad to hear it solved your problems, wasn't much doubt though. :thumbsup: Quote
