well i was running my bros bike wide open for about 3 minutes. then when i let off the throttle i pull in the clutch lever and the bike started making a weird revving noise as though i was still holding the throttle wide open. i tried it again but this time not pulling in the clutch lever and nothing happens. then i did it again w clutch lever and same thing happened, weird reving noise? anyone have this happen???
2 points
first one why are you holding a bike wot for 3 minutes thats a long time to be going wot.
sec i wouldnt suggest pulling in the clutch and holding it while moving at a high rate of speed for very long UNLESS YOU HAVE A PANCAKE BEARING.
2 points
1.) when i say wide open for three minutes im running the gears between 4,5, and 6 full throttle. sorry about that i was trying to explain how i was movingat a real fast rate of speend for a while. It didnt rev crazy when i was moving slow.
sec. when i pulled the clutch in it was for about five seconds.
third do you have any idea what it may have been or are you just bringing up the two points above?
Is it stiil the stock perch, clutch with the park brake??
lol wes
by weird revving "noise" do you mean it was just a noise, or was it really revving up?
it was revving high.
maybe an air leak, what do you think?
Pull both plugs and see what they look like, one side leaner than other ect.
I can check first thing Saturday. Ill let you know. thanks for your help.
